Lathe ID
Jcorcoran
Dec 22, 2020
Hi all
I’m Brand new to the site.
I’ve just acquired my first lathe. I’m trying to get some information on it’s age and operation. I’m currently just cleaning everything and trying to find it a home in my garage.
The lathe has a tag that says Vonnegut Hardware. I assume that they sold the lathe.
It’s a lodge and Shipley. I looked for the serial number in the right rear bee ways and nothing. Is there another location to check for the serial number.
Also how do I post photos?
They made lathes for almost 90 years starting in 1893 so it could be most anything that looked like a lathe
In the very early days it (the serial) was cross wise on a "closing piece" part of the bed casting at extreme right end.
Later all the bed castings were open there and the serial moved further to rear in between two rear vees
Here is a biggie from the closed tail / four vee ways days
This drive is mounted above the headstock and is connected to an electric motor
I am trying to find any information on lubrications and adjustments. As I would like to tear down,clean,and check all the components before use it
Around early teens. Called a FIVE STEP - the number of steps on the spindle "cone" pulley
Mostly by then, they were THREE STEP with double back gear ratios like here from 1916
Here is a FIVE STEP from 1910 - it has some older features than yours - like the threading / feeding gear box controls on the left end
Lube? spindle oil (I'd suggest Mobil Velocite 10) and ISO 68 "hydraulic oil" in the dozen or so "oiling" holes - which being open ended tubes are often plugged up. Eventually, you will want some "way oil" (I'd suggest Mobil Vactra 2) for the bed ways and cross slide
I'd imagine VERY LITTLE in the way of "adjustment" is available. Its either okay or needs to be fixed
Here is what passed for a "manual" in 1921 - its sort of like they could not think of anything else to write down
http://vintagemachinery.org/pubs/2104/6068.pdf
A look at your Post #8 photo suggests you have a 14" L&S - the QC chart has B 14 stamped on it
This number is stamped on the carriage top right corner. I noticed it on another person’s lathe photos. Not sure if it means anything. Or if it’s a part number.
What is the meaning of the stamping on the bottom of the thread placard.
8-14
Maybe January 8 1914?
I looked at the photos you posted and a brochure/catalog from 1916. I see a lathe that closely matches mine.
By the way the cleaning is going well. I’m being careful as I can not to break anything as remove components
from 1916
Except I think you will find that it is too early to have the "double nose spindle" found on all the 1916 machines
Here is that page from 1916. You can't see the threads because they are inside the largest feature
Not having this later spindle just means it has an ordinary threaded spindle nose like this from 1910
