Lathe Identification
Likes Likes:  0
Results 1 to 19 of 19
    Feb 2019
    UNITED KINGDOM
    16
    Default Lathe Identification
    Hello,
    I recently inherited an old lathe from my late Grandfather and i've made it my life's mission to discover the maker.
    I've emailed lathes.co.uk with images and the chap there suggested it was made between 1927 and 1940 and suggested it was German or Eastern European.
    I will add some pictures to this thread later.
    I hope this is in the right section!
    Kind regards,
    Dan
    Sep 2016
    Missouri
    1,085
    889
    349
    Quote Originally Posted by maccas View Post
    Hello,
    Kind regards,
    Dan
    My opinion is you posted your enquiry in the best place on the web for identification. There are some very knowledgable people in this forum. From both sides of the pond and Australia. Worldwide. Some close up pictures and pictures of the whole lathe would be good. Also the quick change gearbox would help.
    In case your new to lathes it's that transmission on the front with the long threaded rod. I apologize if I'm underestimating your knowledge.
    I'm more of a spectator.
    Feb 2019
    UNITED KINGDOM
    16
    Feb 2019
    UNITED KINGDOM
    16
    I'll add some more pictures later. Thanks!
    Dan
    Sep 2016
    Missouri
    1,085
    889
    349
    Dan
    Get pictures of the parts in the boxes if you can. It looks like you have a turret tailstock in addition to the regular tailstock. Any tags or emblems and stamped serial numbers will help identify it.
    Look for stamped numbers on the right end, on the flat area between the v ways.
    Similar to a South bend. But not S.B.
    Jul 2010
    Virginia, USA
    3,592
    87
    705
    Intra-war German, possibly 'badge-engineered' to appear British. It is not one of the common makers like Fischer, L&G or Ehrlich.
    allan
    Apr 2013
    Damascus, MD
    1,629
    4925
    931
    I don't see much similarity with South Bend at all. This looks like a gap-bed lathe, it has both leadscrew and feed rod and what looks like the feed direction lever inside the headstock.
    Paolo
    Feb 2019
    UNITED KINGDOM
    16
    This is great thank you very much! I did scour every page of lathes. Co. Uk and couldn't see one the same.
    I've had it nearly 2 years now, things I have found thus far:
    It is backgeared
    The main bearings are the bronze tapered bush type with c-spanner type adjustment
    The cross feed dial is in metric
    It has a gap bed and a large face plate
    It has axial and powered cross feed separate to the lead screw, with dog clutch style auto-disengage.
    3 speeds on powered cross feed and axial feed
    Leadscrew is in inches (uses 127 tooth gear) to convert to metric
    It has a fixed steady
    8 inch union 4 jaw chuck
    10 inch 3 jaw unknown brand with quick release jaws.
    Inverted ways.
    There is a brass plaque with leadscrew thread pitches on. All in english!
    I'll get some better pictures tonight. I'd love to find out more! My grandad couldn't remember where he got it from.
    Thank you!
    Feb 2019
    UNITED KINGDOM
    16
    Feb 2019
    UNITED KINGDOM
    16
    I've got some more pictures of the lathe now.
  11. #11
    Feb 2019
    UNITED KINGDOM
    16
    Serial number is 2472, which has been stamped in many places on the lathe, under the apron etc. I'm part way through cleaning it all up and painting it. The chip tray isn't standard I don't think.
    How on earth do you add pictures to this site? I've tried the various links from Flickr, tried uploading directly from my pc, nothing seems to work.
    Dan
  12. #12
    Feb 2019
    UNITED KINGDOM
    16
    Figured out the attaching pictures now. Phew. I'll add several more as I go along.
    Dan
  13. #13
    Feb 2019
    UNITED KINGDOM
    16
    Saddle:
  14. #14
    Feb 2019
    UNITED KINGDOM
    16
    Apron and associated gearing. Half nuts have adjustable gib strip. powered feed rod drives x and y directions via pull out knob and lever on the front of the apron. There's also another pull out knob that when you turn prevents the power being put on in the wrong direction if that makes sense. All very nicely made. All threads are metric apart from the leadscrew which is imperial. I have the 127 tooth gear to convert back to metric threads.
  15. #15
    Feb 2019
    UNITED KINGDOM
    16
    Tailstock. Has a lever lock instead of a nut to lock it in position on the bed. Position of tailstock is adjustable for turning tapers and for setting up parallel turning between centres. No locknut on this though and with the backlash in the threaded rod, it can move mid turning if knocked. MT2 taper in the tailstock bore. Very substantial lump for the tailstock.
  16. #16
    Feb 2019
    UNITED KINGDOM
    16
    Gearbox that sits in the headstock for powered feed. Has 4 positions. Neutral, longitudinal feed: 0.7mm / rev, 0.33mm / rev and 0.15mm / rev. Facing feed is 2/3rds of longitudinal feed. Gearbox is chain driven from some gears off the main spindle. Forward and reverse are dealt with by a tumbler on the headstock.
  17. #17
    Feb 2019
    UNITED KINGDOM
    16
    Headstock. Tapered adjustable bronze bushes. 3 speed change on flat belts and also back-geared.
    If anyone spots anything that could help determine the original manufacturer I'd be most pleased.
    Dan
  18. #18
    Feb 2019
    UNITED KINGDOM
    16
    Gap bed.
  19. #19
    Feb 2019
    UNITED KINGDOM
    16
    Fixed steady, change wheels and bed serial number.
