Lathe on a Jeep
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Thread: Lathe on a Jeep
    Nov 2004
    Viborg, Denmark, Europe
    864
    858
    509
    Default Lathe on a Jeep
    Hi!
    My colleague is a proud owner of a Ford produced Jeep, which was part of the D-Day in France.
    He showed me this picture, and we wondered how the drive system works.
    To me it looks like a switch on the right, and a electrical motor on the left. Could that be correct?
    Thx for any inputs.
    Feb 2004
    peekskill, NY
    25,108
    5010
    The lathe I think is a Myford, english design.
    Page Title
    It has electric motor drive from a control box
    behind the lathe, this is probably powered from local mains power unless there's a generator
    somewhere behind the scenes.
    The car is a ford GPW, looks like this in other places:
  3. Likes slnielsen liked this post
    Sep 2005
    West Virginia
    4,028
    442
    The lathe doesn't look like any Myford I've ever seen. But it does look European/British.
    Andy
  5. Likes slnielsen liked this post
  6. #4
    Jul 2013
    Indiana
    3,274
    4804
    1651
    Sorry no help on the drive system here. Please excuse this tangent.
    I understand in War conditions you do what has to be done but it appears that gentlemen has a drill chuck in the spindle holding the work he is turning? I wonder if that was by design?
    By design I mean less collets/parts to transport and keep track of in the field?
    Brent
  7. Likes slnielsen liked this post
  8. #5
    Apr 2004
    Shandaken, NY, USA
    4,447
    1301
    7300
    The lathe is electrically driven. ON many of the military vehicles used by the US in WWII, a 24 volt electrical system was standard, even on some of the Jeeps if I am not mistaken. There was usually a 24 volt receptacle on the vehicle so that various 24 volt equipment could be powered by the vehicle's electrical system. The later series of Jeep, the M 38 A 1, had a place for this electrical receptacle stamped into the side of the front fender, and had a second battery box up in the cowling.
    Civilian C J 5 jeeps had the same opening in the cowling for the second battery box, but the factory crimped a stamped steel cover onto it. I owned a 1960 or 61 Willys CJ5, and it had that second "battery box" in the cowling. After a minor fender bender, I bought an M 38A1 fender, complete with blackout light, and it bolted right up to my CJ 5.
    My guess for the lathe in this photo is that it either ran on 24 volts, or ran on power produced by a generator driven by the Jeep's power takeoff. The transfer cases on the first generations of Jeeps had two levers. One was simply to throw the front axle in or out of engagement. The second lever had three positions: high range, neutral, and low range. There was a mechanical interlock so the transfer case could only be shifted into low range if the front axle was engaged. The transfer case was dirt simple and used spur gears. It had a round sheet metal cover bolted to the back of it, in line with the transmission output shaft. This was for bolting up a power takeoff unit (PTO). The PTO was most often used on the military vehicles to drive a winch. However, it could also be used to drive any number of other things, including generators. The transmission was put into 3d gear to get the necessary rpm, the transfer case was put in neutral and the PTO thrown into engagement to run something like a generator without the vehicle moving along. The generator might have been mounted on the rear cargo area of the Jeep with a belt or chain drive going down thru the floor pan to the PTO shaft.
    Years ago, I was taking an airline flight from some overseas job. The aircraft was sitting on the tarmac and I was watching things going on outside the plane. An open Land Rover pulled up with two guys in it. They had a fuel transfer pump to run, and it was mounted on the rear cargo deck of the Land Rover. As I looked out my window, I watched how they got the pump working. One guy ran out the hoses, and the other guy took vee belts and dropped them thru a cutout in the floor pan. I saw him take a spoked vee belt pulley from the back of the Land Rover and put the vee belts on it, then work it onto the pump shaft. Lastly, he tightened the taper lock bushing.
    With that done, he started the Land Rover, shifted in the PTO and let out the clutch. I saw the hoses jerk as the pump took suction and began delivering fuel. I remember thinking it was a crude but effective way to rig up a pump off the PTO and wondered why, if the Land Rover was a ground support vehicle at the airfield, they just did not leave the pump belted to the PTO.
    Getting back to the OP's question, Jeeps did get fitted with PTO units quite regularly for military and civilian service. After WWII, Hobart even offered a self-propelled welder. This consisted of a Willys Jeep with PTO and a Hobart welding generator mounted on the cargo deck, belted off the PTO. As for the lathe in the picture, the size and type of the disconnect switch is such that it may well be running on 110 or 220 volt current rather than 24 volts DC. Possibly, the Jeep has a 110 or 220 volt generator run of its PTO, or a separate portable generator (known as a "field generator") was in use. During WWII, the US Military had portable generators run by larger Briggs and Stratton engines, on a kind of "wheelbarrow" carrier with a single steel front wheel. The next step up were field generators which were powered by either small Hercules or Willys engines. Any of these are possible means of powering up the lathe in the photo.
    Brent: South Bend did offer a drill-type of chuck threaded to mount on the spindles of their 9" and 10" lathes. It was offered as a work-holding device, and I have one of those chucks for my South Bend light 10" lathe. For turning light and small jobs, as heretical and contrary as it might seem, the heavy-duty drill chucks worked fine. If you were making a small bushing, turning small work with light cuts, or polishing a small part to take off the burrs or size it down a bit, the chuck worked fine. As you wrote, it was "war conditions". Bouncing around rough country, even behind the lines, to make repairs meant keeping things simple and to a minimum. Not that much room on a Jeep to begin with, and keeping the necessary and minimum amount of tooling was what it was about. The name of the game was "git 'er done".
  9. #6
    Mar 2005
    Somerset, UK
    5,066
    645
    1893
    'Aitape, New Guinea. 8 February 1945. The versatile jeep, once more proves it is invaluable. New use is found for it, in this 'transportable' machine-shop. The jeep is driven to any given position, where it's engine drives a built-in generator, which in turn supplies current for, (all built-in) lathe, electric drill, grindstone and hone, battery charger, and a complete lighting plant. Here Craftsman Ron Green of Melbourne, Vic, is operating the lathe. Note the logo shows the crocodile under the palm tree over a boomerang.'
    Source: The Australian War Memorial:-
    Aitape, New Guinea. 8 February 1945. The versatile jeep, once more proves it is invaluable. New ... | The Australian War Memorial
  10. #7
    Oct 2012
    324
    124
    148
    Quote Originally Posted by Joe Michaels View Post
    The WWII Jeeps were 6V. there may have been some 12V or 24V versions for radio jeeps. My 43 Dodge WC-63 was originally 6 volt also. Not sure about the CCKWs. 24V didn't become the standard until the M-series in the 1950's.
  11. Likes slnielsen liked this post
  12. #8
    Jan 2007
    Norfolk, UK
    19,678
    15124
    15289
    Quote Originally Posted by yardbird View Post
    Brent
    Dunno about that pic but I've used a drill chuck as a lathe workholder many times, (often shock horror gasp held in the lathe chuck, …………..IIRC Southbend used to sell a ''Jacobs style'' (dunno if it was Jacobs) drill chuck, bored and threaded to fit straight on the spindle.
  13. Likes slnielsen, Greg White liked this post
  14. #9
    Jun 2012
    Michigan
    11,313
    3875
    3993
    Lathe looks like a 1940 or 41 south bend 10" to me.
  15. Likes slnielsen liked this post
  16. #10
    Feb 2011
    2,440
    1926
    1077
    I've got one of those spindle threaded Jacobs chucks. Its handy for a lot of work as it's very low profile. Just don't expect 4-jaw accuracy.
    I remember looking through a WW2 book of my father-in-laws (can't recall the name). In one picture, a couple of guys had a jeep winched with the nose vertical in the air while they comfortably worked on the drive-train. The caption talked about one of the great advantages the Allies had over the Axis is that even though their equipment may not have always been the best quality, they had much more resourceful troops who would find a way to patch things up and keep them going.
    edit: I think it was "The Greatest Generation" by Tom Brokaw
  17. #11
    Oct 2010
    Dewees Texas
    2,566
    29
    735
    I know there is a South Bend/Boxford connection, Myfords are not related. The lathe in the photo is a gap bed. Did any of those mentioned make a gap bed lathe?
  18. Likes slnielsen liked this post
  19. #12
    Feb 2004
    peekskill, NY
    25,108
    5010
    Quote Originally Posted by Andy FitzGibbon View Post
    Andy
    Look at the pictures in the link I gave. It's probably an early ML2.
    Jim
  20. Likes slnielsen liked this post
  21. #13
    Feb 2004
    peekskill, NY
    25,108
    5010
    Quote Originally Posted by FredC View Post
    Myford ML2 is a gap bed machine. Look at the photos in that link.
  22. Likes slnielsen liked this post
  23. #14
    Jun 2012
    Michigan
    11,313
    3875
    3993
  24. Likes yardbird, slnielsen liked this post
  25. #15
    Sep 2005
    West Virginia
    4,028
    442
    Quote Originally Posted by jim rozen View Post
    Jim
    I know what Myfords look like. This doesn't look like one. Compare, among many other small differences, the size and shape of the bed foot.
    This type of single-foot utility lathe was fairly common in Britain, as a look through Tony's site will attest. Quite a few manufacturers made a machine of this style.
    Andy
  26. Likes slnielsen liked this post
  27. #16
    Jan 2002
    West Coast, USA
    8,307
    562
    5801
    Quote Originally Posted by Limy Sami View Post
    Jacobs used to sell a pair of 3 jaw chucks into motor shops. One was either MT-mounted or threaded to fit the lathe spindle and would drive a motor armature. The other had brass pads to act (just loosely gripping) as a "bearing" tailstock center. My own set, still handy for some work, has the spindle thread end but lacks the original case:
    Cool Jeep.
  28. Likes yardbird, slnielsen liked this post
  29. #17
    Apr 2004
    Shandaken, NY, USA
    4,447
    1301
    7300
    sinielsen:
    Here is a little story about the Willys MB and the Ford GPW Jeeps. Back in the fall of 1982, my wife and I had been married only a few months and were living in our first apartment. With winter drawing on, two fellows who had a business across the road offered to let me keep my motorcycle in one of their buildings for winter. They had a WWII Jeep they used to plow the snow on the business property. It was a Jeep that had been fitted with a home-made cab made of plywood, and had a hydraulic plow lift on the front. It had been brush-painted with Rustoleum red primer paint and looked like a beat up Jeep. One evening, with snow in the forecast, the two fellows called my wife asking if I was home from work. When I walked into the apartment, my wife said the fellows had called to say they could not get their old Jeep started, snow coming, and would I come by and take a look and see what was wrong. I got over to their place and quickly determined the Jeep engine had no compression, and only by putting some heavy gear lube in the spark plug holes could we get the engine to have any compression. Nothing to do but remove the cylinder head and see what was going on in that engine. We got the head removed, and found each cylinder had very heavy wear, with a ridge you could damned near fall off of. I could wiggle the pistons with my fingers in the cylinder bores. I told the fellows to pull the engine out of the Jeep as it looked like the cylinder would need to be rebored and oversized pistons fitted. With that, I went home to my bride.
    They pulled the engine the next day, and called me at work to tell me as much. I said I'd be by that evening to mike things up and see what we were dealing with. I did not need any micrometers or my Starrett cylinder bore gauge (a dial indicator device for checking cylinders for roundness and taper) to tell how worn things were.
    I said the block had to go to an automotive machine shop and to send along the crankshaft and con rods as the crank journals miked a bit out of round and had already been ground undersized once.
    When the block and parts came back from the automotive machine shop, my wife and I started re-assembling the Jeep engine. Wife had never seen this sort of work done, and as a new bride, was wanting to be with her husband on weekends, since I worked all week. We got the engine back together, and I noticed the ring gear teeth on the flywheel had the corners fairly chewed up. I took the flywheel to work at the hydroelectric powerplant construction site where we had an oxyacetylene torch and rosebud. I heated the ring gear and it popped off the flywheel. I then flipped the ring gear around so the un-worn corners of the gear teeth would meet the starter pinion. As I worked on the flywheel, I saw the "Ford oval" logo. OK, I figured it was a Ford engine in a Willys MB Jeep.
    When I got back to working on the engine, I found a rebuild tag on the block from the Mechanicsburg Army Depot in Pennsylvania. It had a rebuild date back in the 1950's. It gave the rebuild specs and this is where things got more interesting. Seems the Army had bored the block to 0.010" over. They had apparently put that engine back together with pistons that were not the oversize pistons, but did use an oversize ring set. That poor Jeep engine had run for maybe 30 years with that condition. The Army tag also indicated the crank had been ground undersized, but made no mention of playing "mix and match" with Willys and Ford parts. The block was Willys, as was the rest of the Jeep. The crank and flywheel both had the Ford "oval" logo on them.
    N.B. Naegle:
    I agree that the generation who served in the US Military in WWII and backed things up at home were the finest generation. I am the son of parents who were of that generation, Dad being a WWII vet and Mom having worked in the Office of War Information. I am sitting here at the computer having come from the funeral of one our congregants. He was about 95 years old, and a veteran of the US Army Air Corps. An amazing man in so many ways, and a real pillar of not only our congregation but the community. The local American Legion Post did the military honors, and we all stood at the graveside despite a series of thunderstorms.
    My own father used to tell me bits and pieces about his time in the US Army in Europe during WWII. As you note, our military was made up of people who came from all walks of life. Having survived the Great Depression and much else, this generation was used to improvising, working with what was at hand, and doing whatever it took to get a job done. Dad spoke a good high German, so he got called upon to translate and interface with local officials in areas that had been conquered by the Allies, and also conversed with some of the German soldiers. A little story of my father's kind of sums up why our military was more adaptable. Dad said he was talking to some captured German officers (Dad was a private), and the captured officers were offered US Army rations. The German officers response was to tell Dad that they expected "officer's rations" rather than the same rations the enlisted men ate. Dad set them straight. He let them know that in the US Army, everyone at the same rations in the combat areas.
    I think the US is a wonderful country where people are a lot less rigid in their views and thinking than a lot of other places. Having worked amongst oldtime German immigrant machinists and worked overseas, I see a difference in how we think and act. We tend to be a lot less restrained or formal for want of a better way to put it. As a result, whether on the home front or in the military, our people were unafraid to "think outside the box" (as it is currently called) rather than "go by the book". If it meant hanging a Jeep by the wire rope of its winch to work on it, it was a quick and easy way to do repairs on the underside of the Jeep. Not by the book or what a person might learn in mechanics' school, but in the field where the name of the game was to get the Jeep back into action, it worked fine.
    Supposedly, the German military was quite impressed by captured US Jeeps. As the story goes, the German high command or some Nazi bigwigs had joked that they wanted to send Henry Ford a letter requesting a few thousand GPW's be built for the German military. The letter supposedly said the Germans had full confidence that they would be victorious over the USA, and would "pick the GPW's up when they got to Detroit". Probably just one of those stories you hear and discount, but our Jeeps and GPW's did have the advantage of being 4 x 4's while the German military equivalent, the "Kubelwagen" (bucket wagon) was 4 x 2 and not quite so rugged and forgiving as the Jeeps.
    I agree that degree of engineering development and quality of the German military equipment was initially often of a higher caliber (pardon the pun) than what the US was producing and using. This adherence to tighter tolerances and closer fits apparently came back to bite the German military on the Russian Front. As I read somewhere along the line, the German government had dismissed the Soviet built arms and equipment as crude. They had the advantage until the Russian winter took over. As I read, the temperature kept dropping and one morning, it had dropped to the point that a combination of close fits on working parts of artillery and other mechanisms coupled with the lubricant thickening at that low temperature made a lot of the artillery pieces and much else unworkable. It was then that what the Germans dismissed as sloppy workmanship suddenly showed its advantage as the Russians kept right on with their artillery and equipment working in that extreme cold.
    In working on the WWII era Jeeps (to use the generic term), I was always impressed by the combinations of simplicity, ruggedness, and at the same time, engineering excellence in some areas. The WWII era Jeep front ends used a constant velocity joint called a "Rzeppa (sp ?) " joint. A pre=war Czech invention. These CV joints were fully enclosed in spherical shrouding with felt seals. Later civilian Jeeps use a simple open U joint at each front wheel spindle. Similarly, the WWII Jeeps had a full floating or "timken" type rear end so parts from front and rear ends would interchange. The WWII Jeep was the right combination of simplicity, ruggedness and good design for what it was. I would not want to drive a WWII era Jeep in today's traffic, nor would it keep up with today's highway speeds. It was a vehicle designed and built for one purpose with one design philosophy and it did well at it. The civilian Jeep vehicles that have evolved, other than being 4 x 4's and having the name, have little else in common with the original Jeeps. Gussied up, fancy and hardly the kind of vehicle you'd take over rough country and bang around with.
    The Willys Jeep design endured for longer than Willys (who folded into Kaiser and then American Motors around 1962-64 I think). In 1981, I went on a job in the backwoods of Paraguay. At the sawmill camp where I was to work, they had a Jeep. When I saw it, I did a bit of a double take. It was a new CJ-5 that had all the features of my 1961 Willys, down to the battery box cover up on the cowling, and it had one vacuum operated windshield wiper on the driver's side and the hand-cranked wiper on the passenger side. It also had the old two-lever transfer case and the three speed manual transmission. Even the instrument cluster (made in the US by AC Delco, IIRC) was the same- speedometer with the fuel, engine oil pressure, coolant temperature and charging ammeter ringing the speedometer dial all in one unit.
    The cover plate was on the driver's side floor pan for accessing the master brake cylinder, meaning this Jeep still had the old "single circuit" brake system. What was needling me was the Jeep looked almost new.
    When this Jeep was started up, it did not sound at all like a Willys with the "Hurricane 4"- the F head (intake over exhaust valve) version of the "Go Devil" (the flathead 4 cylinder engine used by the military jeeps). I asked to look under the hood before we started on our way. I saw an overhead cam 4 cylinder engine and the camshaft cover was "Ford Blue". I recognized a Pinto engine. I looked on the firewall for a maker's tag and saw: "Ford do Brasil". Apparently, Ford of Brazil had bought the old Willys CJ5 design properties and maybe bought some of the tooling. What they were producing as of 1981 for sale in Brazil and the surrounding countries was a dead wringer for a 1950's- maybe 1964 CJ5, with the only differences being the Ford Pinto engine and the lack of the Willys name on it.
    We knocked the hell out of that Jeep on the 2 rut backroads of Paraguay. On one occasion, a fellow from the sawmill camp invited everyone in our camp to a wedding in his village. We got there in the Jeep. We took off the windshield and people rode on the hood, front and rear bumpers, cargo deck, and hanging off the sides on the boarding steps.
    Sometimes, in weaker moments, I think I ought to get myself either an original Willys 4 x 4 pickup or an original CJ 5, before American Motors and Chrysler and all the other late comers changed them from a utility vehicle to the present forms. Then, the reality of taking on another project and having to maintain another vehicle takes hold and I return to reality.
  30. #18
    Oct 2010
    Dewees Texas
    2,566
    29
    735
    Definitely some similarities to the Myfords in your link. They sure had a bunch of different ways to attach the head stock.
  31. Likes slnielsen liked this post
  32. #19
    Feb 2004
    peekskill, NY
    25,108
    5010
    Andy
    I bow to your superior lathe ID skills - so what kind of machine is it?
  33. Likes slnielsen liked this post
  34. #20
    Feb 2004
    peekskill, NY
    25,108
    5010
    " I would not want to drive a WWII era Jeep in today's traffic, nor would it keep up with today's highway speeds."
    Smart. I did, and it was something. That's me in the photo above and I had helped my neighbor get that jeep running
    in good condition. I spent a winter rebuilding the gearbox and transfer case, and basicallly re-wired it stem to stern, to
    make up for years of neglect.
    Once it was running well we used to go out evenings to get coffee and donuts. That thing was hot in the summer, freezing
    in the winter, manual wiper (yep, one wiper) and if you could coax it to go 50 mph you knew you were close to death.
    Yes, single circuit hydraulic brakes, and also a driveshaft mounted drum parking brake.
    Jeeps like that were designed with a lifespan of about 12 hours. That was the mean time to destruction in battlefield conditions.
    They were also originally designed to be lifted by hand out of sticky situations. Notice the hand-holds placed at each corner.
    There was a fair amount of design shift over the time they were thinking about this. Made the vehicle heavier but left the
    four handholds!
    The air cleaner in those things are oil-bath with metal mesh inside, the bottom of the cleaner snaps off. The jeep my neighbor had,
    had the upper part of the air cleaner with louvers punched out along the firewall side. Problem with those was, water would
    get under the rear lip of the hood in rain, and run down the outside of the aircleaner housing. The louvers do not stand proud
    enough to exlude the water - and the air cleaner would fill up with water, with the oil floating on top. This would choke the
    air off going through the air cleaner and the motor would run quite badly.
    Best feature in this jeep is the fuel filter. Firewall mounted, with a nut on the bottom to undo the steel bowl. Inside is a stack
    of brass plates held together with a spring. Each brass plate has a radial groove about 0.003 thou deep stamped into one side.
    Put together they make a pretty good filter for just about any particulate you might find in the fuel - remove the bowl and
    the entire stack falls open so the junk can be flushed out.
    Brings back memories. The jeep still runs, but I recall being amazed at how little there was in the ford three speed gearbox, and how
    light it was. The transfer case weighs in about twice what the gearbox did!
