Lathe Springfield..from Italy
Results 1 to 13 of 13
    Jan 2020
    ITALY
    5
    Default Lathe Springfield..from Italy
    Hello everyone, I write to you from Italy ,someone can help me on this lathe ,Springfield machine ohio, the only thing I know has arrived in Italy with the Marshall Plan
    Jun 2003
    Mebane North Carolina USA
    6,738
    53
    1953
    Picture? Model#? At this point nobody can help.
    Jan 2020
    ITALY
    5
    sorry I can not post photos, how should I do
    Feb 2005
    1,204
    979
    1041
    To insert photos go to advanced reply, scroll down to manage attachments and then add files.
    Jan 2020
    ITALY
    5
    sorry here are the photos
    Attached Thumbnails Attached Thumbnails 20200110_214624.jpg   img-20191201-wa0000.jpg   img-20191201-wa0001.jpg
  6. Likes cutting oil Mac liked this post
    Dec 2015
    Illinois
    458
    166
    259
    Nice looking lathe, what do you need help with?
    Jan 2020
    ITALY
    5
    I wanted to know how old, then if someone had documentation drawings, and if someone explains to me the thread table thank you
  9. #8
    Jan 2020
    ITALY
    5
    I understand the gears, but I do not understand the step 2,3,4,5,6,7,8,9,10 etc,etc
  10. #9
    Nov 2007
    marysville ohio
    9,570
    2749
    6368
    I don't know for sure but I would think that beauty was around long before the big war and the Marshall plan.
  11. #10
    Dec 2012
    AUSTRALIA
    2,575
    10
    803
    The threads are in threads (cuts) per inch..(Whitworths system) ...not metric where the pitch is also the dimension.....You can cut metric threads,but will need a 127 tooth change gear.....there are other combinations using smaller gears that give a close approximation.
  12. #11
    Feb 2005
    1,204
    979
    1041
    The threads are imperial threads per inch. SPDL is the change gear that goes on top driven from the spindle, SCR is the change gear that goes on the lead screw. The lathe probably dates from around 1910 to 1915 give or take a few years.
  13. #12
    Jul 2004
    Houston, TX USA
    30,434
    Let's say you were in the 8 row. Those gears in that lathe would result in the lathe cutting 8 threads per inch, about like a 3.18 pitch metric thread
    The image below shows the basics of transposing or translating gears to make such a lathe capable of cutting metric threads. The F and E gears work together as one gear and are referred to as a COMPOUND. They would be like 127 teeth and 100 teeth
    If we still had the row 8 gears in place - and if the lathe did in fact have the 127/100 compound - it would cut a 2.5 mm pitch thread.
    Here is the quite simple math:
    lead of 8 pitch screw in inches = .125"
    ratio of compound = 127 / 100 = 1.27 : 1
    .125" / 1.27 = .09843"
    .09843 X 25.4 = 2.5 mm
    Other tooth counts can come very close as to compound
    80 / 63 = 1.26984 : 1
  14. #13
    Jul 2004
    Houston, TX USA
    30,434
    I see the row 8 gears are 72 and 96 - meaning the lead screw of the lathe is 6 pitch
    96/72 = 1.33333 : 1
    .125" X 1.3333 = .16666"
    Reciprocal of .16666 = 6
