LeBlond Spindle Lubrication
Results 1 to 5 of 5
    Dec 2019
    Illinois
    77
    17
    Default LeBlond Spindle Lubrication
    I realized that there was "stuff" floating in the lubricators of my new LeBlond (1904, 17" swing, cone drive)so I tore into them.
    I have read of wicks used to regulate lube to the LeBlond spindles, but observe no trace of any.
    Should there have been wicks? If so, what do I use as a replacement?
    The "stuff" turned out to be large chips and white balls of something?
    The lube units turned out to be Lunkenheimer No. 3 Fig. 1300 Sentinel. Is this original?
    They have a needle valve with toggle. It seems to be used to open or close lubrication.
    When would one shut off lubrication? Or does excessive lube just leak out so the needle in retracted for a short time before each use?
    Jul 2004
    Houston, TX USA
    30,480
    Total loss they call it. I expect a few were turned off over night, but only if the BULL made it plain that was expected. There were low pay folks hired as wipers to clean up the mess now and then - likely doubling as "CHIP MAN!" - often called on
    Its adjustable "drip" or flow rate - wicks would seem superfluous - being handy for non regulated delivery situations
    Some - maybe not these - have a foam ring "filter" at bottom - so the chips and other caca won't being visiting the bearings
    If it was mine, I would have a very light bodied oil in there - like Mobil Velocite #10 (the thread does have to do with SPINDLE lubrication)
    Dec 2019
    Illinois
    77
    17
    The lower glass lets you count the seconds between drips, and precisely adjust the rate. Any idea how many drips per min. would be suitable?
    The color of the oil is off (at least on my computer). That is DTE 32. I will get some lighter stuff...
    Apr 2004
    Shandaken, NY, USA
    4,384
    1225
    7060
    I run ISO 46 oil in my old machine tools and much else. It is available in 2 gallon jugs at places like Tractor Supply, sold as "Tractor Hydraulic Oil". Tractor Hydraulic Oil is a DTE medium (ISO 68) or DTE Light (ISO 46, I think). Tractor hydraulic oil is a DTE (Dynamo, Turbine, Engine) oil, straight weight, mineral base, with anti foam and anti corrosion additives. Plenty good for old machine tools with plain bearings and for older geared-head machine tools.
    DTE usually does not have "number" weights or grades. Typically, DTE oils are specified as "Light, Medium, Heavy-Medium, and Heavy". An ISO viscosity rating now accompanies the DTE classification. ISO 46 is about an SAE 20 weight oil. ISO 32 may be too thin for your application and will run out of the bearings as fast as the lubricator drips it in.
    As for drip rate on the lubricators, I like to see a couple of drops a minute at most. Nothing precise about it. Start the lathe once you have established oil flow from the lubricators to the bearings. Run the spindle at each speed (in "direct", not back gears) and feel the bearing caps. If they are getting hot rapidly, open the lubricators wide, flood the oil to it, and loosen the bearing cap bolts. You may have set a bearing up too tight and will need to add maybe a 0.001" shim. If the bearings take their time in getting warm (if at all), after about 10 minutes of running at the lowest speed, shift the belt to the next steps on the cone pulleys and kick the speed up. Repeat the process, feeling for hot bearings. There are two loose rules about this: if a bearing gets hot rapidly, it is likely setup too tight; and, if you cannot keep your hand or fingers comfortably on a bearing cap, it is running too hot and is setup too tight. Use the backs of your hands/fingers to feel for bearing temperature as the tips and front of your fingers/palm may be too callussed to give you an accurate feel. Kind of like a mother feeling a child's forehead for fever, using the back of the hand.
    At the highest spindle speed in "direct", if the bearings begin to warm up, increase the oil drip rate a bit and see if the temperature of the bearing(s) stabilizes.
    When this happens, the lathe should be ready for use and taking some trial cuts. Oil is cheap at the price.
    BTW: the old drip lubricators used compressed cork gaskets between the glass and the brass end flanges. The cork avoided putting localized high stress on the glass (which may not have been cut off entirely flat or squarely), with resulting breakage of the glass. The cork gaskets were sealed with gasket shellac, a blackish product that is probably ancient history now that RTV gasket eliminator and silicon gaskets have taken over from the old cork gaskets. The old cork gaskets are probably about like petrified dinosaur droppings at this point, courtesy of the gasket shellac. We used to buy a small bottle of "Indian Head Gasket Shellac" in the auto parts stores when we worked with cork rocker cover gaskets back 'in the day. If you need new gaskets for the lubricators, some of the suppliers of restoration supplied for the "hit and Miss" gasoline engines such as "Starbolt Supply" may have the cork gaskets. There is enough thickness and "give" in the cork gaskets, making them ideal for use on the lubricators. All too easy to slop on the RTV Gasket Eliminator (or similar), then make up on the lubricator center stem to draw the end flanges tight on the glass... and either it leaks or the glass goes bust.
    In short, get oil flowing to the bearings, and if they run cool at high speeds, you are good to go. Determining what oil to run is another matter. I personally would for an ISO 46 oil given the type of bearings, type of machine tool, and spindle speeds. The oil needs some "body" to it to maintain a wedge-shaped film in the bearings under load. With lower speeds and heavier loadings and looser bearing clearances than something like a surface grinder spindle might have, I'd stick with the ISO 46 and not lose any sleep over it.
    John Oder is correct in that these old machine tools used "total loss" lubrication. In the old shops, they used to get bundles of "cotton waste" for wipers. Cotton waste is the odd threads and small trimmings from textile and garment manufacturing. It is probably an obsolete thing, and even the hemmed red shop cloths are getting fewer. Disposable shop wipes by the roll are in common use. In the old days, the waste was freely used, and there were (if the shop was safety minded), special galvanized steel containers that were fire-rated to hold the oily waste when the machinists or wipers were done with it.
    Oil and shop wipers are cheap at the price, so don't be stingy with either of them. A lot cheaper than having a spindle journal seize in a headstock bearing with resulting damage.
  5. Likes Dr. Hillbilly, mister honey liked this post
    Dec 2019
    Illinois
    77
    17
    Sorry for the senior-moment. My hydraulic oil is labeled ISO 32 - DTE Light, not DTE 32
    And as you predicted, it ran straight through, although I was running at about 12 drops per min. Now I know where to put the drip pan!
    I will let the thin lube run through at low rpm just to purge things, and get some ISO 46 tomorrow. Then I will run your temp/rpm test...
    I do not have any hit-and-miss engines (yet!), but I do have several flathead Ford 4s and V-8s (so I have plenty of cork gasket). In this case I got lucky and did not need it. The old gaskets were in good shape and are not leaking.
    I enjoyed your reference to loosening the bearing cap bolts and shimming. My only previous experience with babbit bearings was with the main and rod bearings on a Ford Model T. They are not rigid, so the shim is approximate, and the fine-tuning is performed with the torque of the cap screws.
  7. Likes Joe Michaels liked this post
