Sven Staar
- Oct 19, 2015
Hello everyone,
I've got a Leinen MLZ4S lathe which came with the wrong motor. And most likely, the wrong V-belt pulleys. Can anyone tell me which size pulleys are supposed to be on the motor?
Here is the more complicated problem. The flat belt pulley in the headstock is making inappropriate noises. I suspect the pulley has a bearing and possibly a planetary gear (or some sort of gear) in it. Can anyone confirm if this is true? Assuming the noise is coming from a damaged part in the pulley, how do I remove the pulley? Can anyone supply an exploded view of the headstock or a repair manual or photos or something? The user's manual doesn't do into depth for repairs.
Thank you all,
Sven
Thank you all,
Sven
