Mel in WA
Hot Rolled
- Aug 29, 2005
- Castle Rock, WA
L Vanice;2821377... My Green engraving machines have endless belts made of braided white cotton thread. They look a bit dirty and ratty after many years of use said:Interesting.
I tried dentist drill belts on a small drill press and a watch lathe. Same deal, braided cotton I found that they slipped and did not work effectively. Replaced with similar diameter green urethane from Small Parts Inc (no longer available) and both work fine with that.
Hello Rusty,
I have Levin lathes that probably use the same pulley groove size as the drill. I use 5 mm (3/16") round urethane belting. I have an expensive Swiss-made electric belt welder that is made for this purpose. But it is possible, with practice, to weld this belting with a heated piece of sheet metal to melt the two ends, then press together so the joint is not offset and let cool. A nail clipper is a suitable tool to cut off the flash around the weld.Hello Rusty,
I live in Spokane, WA just up the road from you. I picked up a Levin mini drill press on Monday at an auction in Seattle. It appears to be in great shape except it also need a new belt. I checked out your ebay link (thanks) and it looks like you need to purchase 10 feet and I am not sure what is the best way to join it. Any chance you would be interested in making a belt for me (for a price of course) and sending it to Spokane? Kevin
Kevin, I just put a flat piece of metal, A piece of metal strapping like they secure things to a pallet with in a vise then heat it with a propane torch. Touch both ends of the belt to the hot metal and when it melts slide the belt up and off the metal holding the ends together until the belt cools. There will be a lot of goopy belt around the joint. You can trim it with a razor blade or use a bench grinder and rotate it will touching it lightly to the wheel. It will look like something the cat drug in but it works. It's almost impossible for both ends to be exactly opposite each other but when it's trimmed or ground it will work. If it doesn't work on the first try just cut it and try again. The belt is stretchy and with the adjustment of the drill press you have a lot of leeway in the length of there belt. I sold my Levin drill press to a guy in Rathdrum and I don't have anymore belting.Hello Rusty,
Product name is Hollow Rounthane urethane belting from Shingle Belting (made in USA). I bought it in 200 foot boxes and sold several hundred feet of 3/16" diameter in yellow and clear with aluminum connectors at NAWCC regionals years ago. That is the product that eventually turned brittle in the box and on my lathes. I switched to the solid green urethane belting from China and have had no trouble with it.There is also hollow belting that uses double ended barb bits to hold it together. Used one for years with my Geneva pattern Lorch & handwheel. Don't know the source, my tutor gave it me when I was in college in the uk.
Notice
