Lift point for a gorton 375
Likes Likes:  0
Results 1 to 3 of 3
    Jun 2012
    Chicago, USA
    1,794
    12
    145
    Default Lift point for a gorton 375
    Hi all
    Has anyone here moved a gorton 375 single lip grinder? It's sitting on my trailer at the moment, but there's not really a handy point to lift from that I can see. If anyone has any suggestions, much appreciated.
    The one pictured is not mine - mine isn't on a pallet, and is top heavy enough that I'd really prefer to lift from above.
    Lee
    Sent from my SM-N960U using Tapatalk
    Sep 2005
    Northern California
    1,152
    195
    Yes, the grinder proper and the cast base were seperate castings. The grinder itself was picked up with a nylon sling around the spindle housing. Take the water pot off first, it simply lifts clear.
    The base casting as I recall had a opening in the top and we grabbed that with bridge clamps and wooden blocks with a nylon sling on each of the bridge clamps
    Jun 2012
    Chicago, USA
    1,794
    12
    145
    Thanks very much!
    I didn't realize the base was a separate casting... That will make it a whole lot more manageable
    Thanks!
