Light relief: Machinery identification challenge! - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21
    Mar 2005
    Somerset, UK
    5,060
    595
    1873
    jd-2020-a15.jpg 9. jd-2020-a16.jpg 10.
    Ader's 'Avion III'.
    I’ll keep an open mind, and suggest that the plane probably wasn't as daft as it looked.
    The propellers appear to be ..... feathered.
    More on the remarkable power plant later.
  2. Likes Jim Christie, franco, Peter S liked this post
  3. #22
    Oct 2002
    Kansas City, Mo.
    6,475
    239
    1929
    Check out the Wikipedia page on it. It has a few more photos. It looks gorgeous hanging in that stairway.
    Ader Avion III - Wikipedia
    Thanks Asquith, that was fun. Maybe more of us should try posting strange things?
  4. Likes cyanidekid, Asquith liked this post
  5. #23
    Jun 2016
    New York
    1,780
    1072
    820
    wow! pretty much says it all...thanks for posting
  6. #24
    Mar 2005
    Somerset, UK
    5,060
    595
    1873
    jd-2020-a11.jpg 11. jd-2020-a6.jpg 12. jd-2020-a5.jpg 13. jd-2020-a14.jpg 14.
    Ader’s aircraft looks ridiculous, but people in the 19thC probably had more reason to be influenced by the success of flying creatures than by contraptions supported by stacks of rectangular wings.
    Regardless of our views on the aircraft, I'm highly impressed by the propulsion system, and the exceptional lengths Ader went to in reducing weight. I'd be surprised if anyone before him had gone to such trouble and expense. Of course, it was aeronautics that drove the need for extreme power-weight ratios. There was a huge flurry of activity in this field at the turn of the century, and I know little about other contemporary engine-makers’ efforts. The engine and boiler look remarkably modern, not least because of the lightweight pipe couplings, and the multi-bolt flanges, and the stainless-like appearance (presumably nickel-plated brass).
    Although the Avion’s engines were built in 1894-7, they closely follow Ader’s engine for his single prop 'Eole', built in 1890.
    The engines are tandem compound.
    The tubular boiler is methanol fired. There are thousands of microbore tubes connected to headers top and bottom. I assume that the curvature of the tubenest is intended to accommodate thermal expansion. The prominent domed vessel is the steam drum. There are two sight glasses to show the level, perhaps of limited value during aerobatics
    Steam is taken from the top of the drum (photo 11), via an internal separator, to a manifold with two valves which send steam to the HP cylinders. In front of the drum is a valve which, as far as I can make out, is a ‘simpling’ valve which allowed high pressure steam to be directed to the low pressure cylinders when more power was required, which might have been quite often
    The exhaust steam was condensed, the condenser sticking out of the top of the aircraft, making it look at bit less 'batty'.
    This drawing shows the power plant, including the fuel system:-
    http://alain.vassel.pagesperso-orang...haudiere2b.gif
    .... From this excellent website, several pages (in French):-
    Avion N°3-3
  7. #25
    May 2002
    Auckland, New Zealand
    4,504
    1855
    506
    Getting off topic a bit, Ader also had a go at building cars (see edit note below).
    I have a book about the infamous Paris to Madrid race of 1903 in which several Ader cars were entered. All seven made it to the fore-shortened finish, though well down the listings.
    The book says that Ader worked on 90 degree V-engines from 1900, they used a forked conrod and single crankpin for each pair of cylinders. The same components could be used in 2, 4 and 8 cylinder V-engines.
    Inlet valves were atmospheric type. Exhaust valves operated by separate camshafts for each bank.
    Entered in the race were 2 cylinder 12 hp (80 x 100mm), 4 cylinder 16 hp (80 x 90mm), and 8 cylinder 32 hp cars.
    Here is one of the 32 hp Ader V8's entered in the 1903 race. Note the surface carburetor on the bulkhead.
    Edit: I have no idea if Clement Ader was personally involved with the cars bearing his name. The cars were apparently built by the Société industrielle des téléphones, who produced telephone equipment using Ader's designs. Perhaps they used Ader's name because it was well-known? Or was Mr Ader an early gear-head who like the sound of a V8 engine...
  8. Likes Asquith, Jim Christie, Paolo_MD liked this post
  9. #26
    Jul 2007
    Florida
    781
    93
    385
    Early Cappuccino Machine?
    CarlBoyd
  10. #27
    Aug 2004
    ventura,ca.usa
    399
    73
    Did it actually fly???
  11. #28
    Jul 2007
    Stratham, Cow Hampshire
    4,268
    440
    1638
    May cause skinny pants, Hitler Youth haircuts & possibly even some goth tendencies.
    What? No purple hair?
    Good job on the mind-tickler.
    Joe in NH
