Machining techniques in a 1941 Horizontal Boring Machine
Temo
Feb 25, 2013
Pomona, Ca
Hi to all, I been working for a while in a 1941 Universal (Horizontal) Boring Machine Co., I got to know the machine a bit know, had the chance to do a couple of repairs.
I'll like to share the limited knowledge that I have of the gear box, both for the speeds and the feeds, to who ever got stuck and can't repair or is afraid to open the gear box, I know one can get overwhelm or intimidated by all the gears and levers.
On the other hand I'll like to ask questions about the stuff that I been dealing with but I haven't got the chance to repair.
If there's another forum that I can post this to help some other old school machinist like me let me know, Thanks in advance!!
Hi,
I have a 1927 Universal HBM. At some point in the past, they replaced one of the gears in the rapid traverse gear train with a blank, my guess is to suppress vibration. At some point in the future, i plan to disassemble the gearbox and make a new gear. I would appreciate any information you have on how to remove the head and anything else you think may be relevant. Please post some pics of your machine as i and i'm sure others would like to see it.
I have a 3" universal I use most every week. I have a manual for it also. If I can be of any assistance.
What kind of tooling? My spindle is #5 mt. I did modify with a lock screw at 15 degrees. I made a adapter that bolts to the 4 bolt outer drive housing to use 50nmtb tooling but you give up extension of the spindle
Hi to all, here are a couple of pictures of the machine, to clarify, I'm a machinist, I operate this machine and have made some repairs.
I see you have Portage Double Quick (PDQ) tool holder.
Nice. I have a Giddings Lewis 25T. Welcome to the club
of owning real size machines that do real size work.
-Doozer
Hi,
On January I made a repair of the rapid traverse, I'll check for pictures when I get home and post if I have them, it was a challenge to adjust the distance of the clutch because at one point the original assembly was change for a different one.
Thanks, any info you can provide would be great. Am i correct in assuming you had to remove the head to get the gearbox cover off? My gear box cover is a shop made replacement. The original must have been broken at some point. I suspect once i get into the gear box i'm also going to have to replace a bunch of bushings as the vertical drive shafts have quite a bit of play in them. I would be very interested in any information you can provide regarding the process for removing the head.
Mark
