michael.kitko
Cast Iron
- Oct 30, 2012
- Pontefract, UK
First off, I am actually impressed by this little hacksaw. I cut quite a bit of steel today with no problems, for the most part. It was jumping a bit and it seemed like the clack that was there was worse than usual.
Well, I did start looking at my machine a bit more today. I opened up the gear box and found a good portion of grease, which got scooped out. I thought the clack was coming from the eccentric arm due to it having set screws which were backing out. Anyways:
So I have some questions and would appreciate any help.
1. The oil slinger in my gear box is missing. Does anyone know what it might look like?
2. I have some pretty terrible grooves in my reciprocating arm, where it looks like it has been run uneven for quite some time. Can I flycut that arm to restore it's geometry?
3. Does anyone have any good pictures of the cam and lobe and the adjustable pin? Mine was broken and I think they tried welding it and then they set screw it with pins into the end of the crank.
Again, thank you for any help.
Sent from my S61 using Tapatalk
