I figured someone here may have an answer to a question that keeps coming up in my mind. Every time I see pictures of large old motors or generators, the sort from the 20’s, I wonder how they were installed. Specifically the armatures had separate mounts from the shaft bearings with no common base. Just separate concrete stems from what I’d presume to be a common footing. How were the footings layed our to be aligned and then subsequently how was the armature installed and the mounts/ bearings shimmed for alignment and concentricity of the armature and rotor?
