Froneck
Titanium
- Dec 4, 2010
- McClure, PA 17059
I have to increase keyway length in 14' X 1-1/2" SS shaft. I have a small #2 size K&T mill. Good accurate 40's vintage or newer.
What is the best way to clamp the shaft to the table using the T slot to set the shaft in? I probably made this shaft long ago when I had bigger mills. My concern is the 3/8" wide mill might grab the shaft and pull it even though I'm careful to be sure back lash is removed. Problem with clamping is I'm limited to the other 2 T slots on the table so the strap clamp stud is quite distant from the shaft. Possibly use a milling vice inverted against a fixed stop will stop the cutter from pulling the shaft?
Note; I screwed-up in topic, shaft is 14 feet long!!
