Monarch 612 28x120 Finally in Shop
Results 1 to 18 of 18
    Apr 2009
    ontario canada
    93
    5
    14
    Default Monarch 612 28x120 Finally in Shop
    Finally got it in my shop. This was from 'Collector' in Vancouver BC. Now on my shop in Ontario. Thanks to a few mbrs here: 'Chriss999', 'Luck7', and 'Rob F', as well as 'collector'. Now to work on the electrical set up. I said i would post some pictures last March when it was shipped- had it in interim storage until last wk. Here they are (yes poor light-my 12 year old son's camera!):
    Mumf
    May 2002
    Auckland, New Zealand
    4,644
    2477
    657
    Here you go, a bit more light on the scene.
    That is an impressive lathe.
    monarch-612-28x120-01.jpg monarch-612-28x120-02.jpg monarch-612-28x120-03.jpg
    Aug 2004
    ventura,ca.usa
    525
    136
    It is indeed an impressive machine. I for one would like to see any pictures of you rigging it to get it where it is... Jim
    Sep 2008
    Canada
    1,506
    590
    586
    Good to see the big girl again!
    And nice that she still has the Carr’s Machining sticker ;-)
    Is that a hydraulic table DoAll?
    Lucky7
    Apr 2009
    ontario canada
    93
    5
    14
    Quote Originally Posted by lucky7 View Post
    Lucky7
    It is a 36inch Doall, not hydraulic though.
    Jan 2015
    Virginia
    166
    108
    29
    Nice lathe. Interesting color choice.
    May 2020
    Minnesota
    227
    89
    62
    Wow. That's a beautiful machine. As they say, go big or go home!
    Color scheme reminds me of the Hogwarts Express!
    Jan 2002
    Sea Cliff, NY & Portland, OR USA
    847
    181
    106
    I believe that was Collector's chosen color for all his machines.
    Tom B.
    May 2011
    southern in.
    1,630
    2141
    429
    Quote Originally Posted by Riderusty View Post
    Tom B.
    The original color would have been light gray. I served out in a shop full of new ones back in the 70's.
    JH
    Nov 2007
    Port Coquitlam BC Canada
    695
    11
    262
    Hi Collector here nice to see you got the lathe set up. Just a note when you start the spindle with the hand lever on the machine or the carriage listen that the brake is not dragging. There’s a sweet spot when pushing the lever down. If you slam it down I think thats when it drags. Oh once the motors are running it’s good to go as it’s a clutch machine. Make sure the hydraulic pump is running the right direction or it won’t run.
    Collector
  11. #11
    Apr 2009
    ontario canada
    93
    5
    14
    Quote Originally Posted by collector View Post
    Collector
    tks collector. I posted in the monarch forum. I may have to use a soft start to keep my amps down. That would mean i would start the main motor only and once it is going switch to all original wiring/functions. So, it seems i would have to over ride the sensor you mention on the hydraulic pump. My main concern would be if i would hurt the bearings with a short start up time before switching to all functions- ie engaging the hydraulic pump, etc. thoughts?
    Mumf
  12. #12
    Apr 2009
    ontario canada
    93
    5
    14
    Just to clarify the above. I have a 20 hp phase convertor i am looking at adding a 15 hp motor to. This to help generate more amps for the 25HP monarch motor. To help keep the amps lower on start up, i am looking at a soft starter. This to start the main mtr and then switch to the original set up to run all the original functions- including the hydraulic pump. I have a lot to cfm with the electronics and it will be a while, but this is the option i think will be best for me. I have looked at VFD, bigger phase convertors etc.
    Mumf
  13. #13
    Virginia
    18,913
    7561
    11644
    Quote Originally Posted by Mumf View Post
    Mumf
    No gain. Don't make a problem out of a solution the OEM already sorted. Leave the sensor as-is. Do the opposite. Start the pump first if it doesn't already JF doo that.
    Once running, it ADDS to RPC stability and the inertia "pool" rather than loading it down as you start the main final-drive motor.
    You probably won't need anything special as to "soft start", either.
    Certainly not if you bring a 15 HP supplementary idler online after starting a 20 HP idler. With 35 HP worth of idler active, plus another small boost from the pump, the 25 HP load-motor should just come wide-awake nearly as fast as if on the Powerco grid.
    Starting load is vicious, but VERY brief.
  14. #14
    Apr 2009
    ontario canada
    93
    5
    14
    tks Thermite, sounds like a plan. I am also concerned about my total amp draw on start up. Just before the lathe I will have a 30KVA transformer that the start up amps will max out. Also my panel is 200 amp, so start up will max it out- not sure if the very brief time frame would be an issue for either of these- hence why I was thinking soft start- if i do not need it would save me cash.....
  15. #15
    Virginia
    18,913
    7561
    11644
    A transformer is a lumped inductance.
    So is a "choke".
    The Iron and Copper don't actually give much of a damn about the distinction nor whether they have one winding or several.
    Saturation is saturation at wotever it is for the construction, etc.
    Rule of thumb, even though a KVA is LESS than one HP, erg-wise, is to use a transformer of twice the KVA as load HP.
    That way, it does NOT significantly limit what the load can grab for peak power.
    Anything much less? Expect some limiting. Mind.... dropping a 50 KVA transformer across the line has a "starting current" of its own!
    Your 35 KVA should be just about right, though.
    Among other things, your transformer IS your "soft start".
    My one is 27 KVA, FWIW... But my largest "running" load is a tad under 10 HP, fully loaded.
    OTOH, NONE of my machines have a mechanical clutch to de-couple the rest of their powertrain at start.
    Keep in mind that the current-rating is the "sustained" figure. Heat-rise determined, mostly
    Short-term peak is determined largely by saturation.
    I think you are in good shape, so far. Conserve yer cash. Wait, try it, then see if you need more "stuff" or not.
  16. Likes Joe Miranda liked this post
  17. #16
    Oct 2004
    Elyria Ohio
    2,003
    4042
    883
    Nice machine and nice shop!
  18. #17
    Virginia
    18,913
    7561
    11644
    Quote Originally Posted by Just a Sparky View Post
    LOL! I LIKE it! Wish I had the paint code!
    I have a similar Benjamin-Moore "Super-Spec" waiting to go on in their own "Chinaberry Red".
  19. #18
    Apr 2009
    ontario canada
    93
    5
    14
    So is a "choke".
    tks Thermite. I will give it a go. I will post results, but it will likely be many months.
