Monarch Model AA (?)
Bologna
Mar 27, 2018
I'm not a machinist, just a hobbyist who likes old tools and sometimes spontaneously buys things when the price is too low to pass up. I bought a Monarch lathe the other day for $50 out of someone's garage and figured I had nothing to lose. I think it's a Model AA, but if someone knows otherwise please correct me. There's no nameplate aside from the feed speeds and an JL Osborne Machy & Tools plate. I believe it's a 16" swing.
There is gunk on the ways like surface rust combined with old cutting oil that's turned to grease, but after cleaning off the right side where the serial number is supposed to be, it says, "Lot 299 Mach 8". The reason of my post: can anyone decifer this for me? I think Lot 299 is the serial number which I think makes this lathe really old, but I don't know what Mach 8 means.
Pictures are too small to see..........
When machines were made in batches, they often gave lot numbers and machine numbers within the lot. I would think that was "machine #8 in lot 299".
I know! There's a 19.5kb limit on picture size so I'm not sure how to make them bigger?
Look at that again - 97.7 KB for jpg - plus the system automatically resizes larger to be around that limit.
Example thumbnail resized from 655 Kb to 95.5
Ah hah! Ok let me try this again. Are these pictures better?
I can at least see the antique shift levers - and AMAZINGLY - the ball bearing taper attachment - which I will suppose came from a later machine
Appears to have the lift-off covers over spindle bearings, indicating plain (bronze or Babbitt-style versions) spindle bearings
No doubt has threaded spindle nose
Basically the first of the helical geared head stocks, but no anti friction spindle bearings, standardized spindle nose or hardened and ground bed ways - all of which were in the future.
There are older Monarch gear heads, with non helical gearing and shift levers in a tight cluster
Earliest non-lot-number serial appears in the serial book for 1927, making your lathe older than that
Related set up pub from about 1930 - thanks to John Legge and Greg Menke
http://pounceatron.dreamhosters.com/docs/monarch/monarch-modelc-setup-bulletin-127-1930.pdf
Thanks. Can you confirm that it's a Model AA? Also do you happen to know if I'm able to look up this serial number/lot number to get the year or info on it?
No to both. You could try calling Monarch, but they likely won't know much about their nearly 95 year old products
No, I don't know the phone number - or even if they still refer to themselves as Monarch Machine
Lots of info here, but nothing from that far back. The 12" AA pub is a far more modern design
Monarch Machine Tool Co. - Publication Reprints | VintageMachinery.org
Here is as close as you will get, but undated. The "ball bearing" refers to primary shafting, not spindle bearings. No model designation like "AA"
A close look at the aprons in this brochure show that it predates the modern apron clutches introduced in May of 1925
The old "star knob" apron clutches are shown
http://vintagemachinery.org/pubs/2103/17383.pdf
Amazing but apparently the case. Link in Post #11 shows both the 14 and 16" having 3 X 5 front spindle bearing and 2 3/4-6 spindle nose thread
Thumbnail shows these to ALSO be used on 18 and 20" machines
No, It doesn't, That is my brochure that I scanned for the website. Comparing the brochure to my machine they are the same. Mine does not have any plates on it that I can find other than the speed/feed for threads. I found another machine like mine on a website( forgot where) that showed it an AA looking like mine and Bologna's. Mine came from the N&W Railroad shops. Mine also has the same base as the Brochure.
Ben
