ppdebo
- Dec 19, 2014
Handy looking tool, and it looks to be in fair nick, 30 taper as well?
FYI there was a Mondiale in Belguim who made lathes http://www.lathes.co.uk/mondiale/ and from what I can make out you mill has the same (ish) logo on the base door.
I am also thinking of increasing the distance/clearance between the chuck (or collet) and the table face when using the vertical head attachment. Since the vertical attachment is rather bulky, it reduces the clearance between the cutting bit tip and the tabletop face. I was thinking of adding a 100mm spacer (iron channel) on both sides between the top part of the machine and its base, just above the tray. However, when the knee is fully down, it will not be completely locked into the gibs if I do this 100mm height extension. This Delta machine was primarily a horizontal mill.
I have to think well about this before doing it. I also need to find a way to lift the machine!
The red circle in the attached picture is where I intend to insert the 100mm x 50mm box channel in order to increase the head height.
Notice
