More Hendey questions
Likes Likes:  0
Results 1 to 7 of 7
    Apr 2015
    Wisconsin
    14
    Default More Hendey questions
    Hi, I have finally gotten back to my 16x54 Hendey project. I got the lathe for basically scrap and don't know any history, particularly what all wasn't working before I got it. I am at the point of putting the longitudinal feed clutch in the apron together. (I'm trying to upload pic's with no success yet) When I tighten down the nut (round disk with 2 flats) and put in the set screws there is still at least 1/16 inch end play between the the thrust bearing and the shouldered keeper under the nut with the clutch disengaged and an additional 1/8 play with the clutch engaged. Also with the clutch disengaged the gear that runs in the lead screw is against the right angle plate bolted to the end of the apron and with the clutch engaged there is still only a couple of thousands clearance between the gear and the angle plate. I don't know if it was working before I got it, can all that play be taken up from the outside by adjusting the clutch or am I missing something. I know this is tough without pics, thanks for your expert advise.
    Jul 2004
    Houston, TX USA
    29,496
    I'll scan the six pages of Patent 1,972,373 (4 September 1934) here in a bit and edit them in here. Not exact as far as what actuates them, but may be useful/helpful as far as internal parts and how they fit together. Sort of interim design showing long clutch still in center on carriage hand wheel.
    Here are the first five pages
    This document can be emailed as a pdf if you care to PM me that address
    Attached Thumbnails Attached Thumbnails 1972373_1.jpg   1972373_2.jpg   1972373_3.jpg   1972373_4.jpg   1972373_5.jpg
    Jul 2004
    Houston, TX USA
    29,496
    Here is the sixth page
    Apr 2015
    Wisconsin
    14
    I hope pics come through. 1st space with clutch disengaged.
    Apr 2015
    Wisconsin
    14
    ok try again 1st pic was how close gear is to angle iron. hopefully 2nd will be of clearance with clutch disengaged.20190821_132050.jpg
    Apr 2015
    Wisconsin
    14
    Sep 2014
    Georgia
    400
    567
    207
    Here's some more picture that M1782t sent me.
    Attached Thumbnails Attached Thumbnails 20190821_132821.jpg   20190821_132638.jpg   20190821_132627.jpg   20190821_132613.jpg
