There is a really scary youtube on the Pakistani Truck Channel about the repair of a heavy truck rear end. The wheel spindle had broken off at the end. The Pakistani mechanics set the rear end up in the same belt drive lathe and chuck the undamaged side's spindle. Seeing a whole truck rear end flying around in the lathe with no counterbalance weights is something I found amazing. The mechanic cuts a 'vee' in the damaged spindle where it meets the flange on the rear end's body. He does not part it off completely. The rear end is then landed on the ground and the damaged spindle is broke off with a sledge hammer. A partial replacement spindle section (maybe cut from another similar rear end with even more damage) is bevelled in the lathe. The rear end goes back into the lathe and the repair section is jigged onto the rear end using the tailstock to support it and hold things in line. Welding is done with a bent electrode and hand held shield, no ground clamp anywhere in sight.
After the first few stitch welds go in, the mechanic rotates the rear end in the lathe by hand and hits it with the sledge to knock down any bowing. He runs multiple stitch welds to tie the repair spindle section to the rear end while it is in the lathe. The rear is then taken out of the lathe, placed on home-made roller stands on the ground, and the welding is completed. The mechanic uses a really wide weave for the welding, apparently never having heard about limiting the width of a weave bead.
When the welding is finally done, the rear is checked again for any bowing, and is straightened in a hydraulic press located outside of the shop.
When the rear end repair is completed, two men in the usual sandals or slippers heave the rear end onto a well worn and beat-up hand truck and schlepp it over dry and dusty dirt yards and roads to the truck repair location.
Seeing a heavy truck rear spinning in a lathe that is way too light for the job and with no balance weights is something I'd not have believed had I not seen it on this particular youtube. I am curious as to what welding electrode the Pakistani mechanics use. Apparently, the flux is durable enough to allow the electrodes to be bent. I am guessing the Pakistani mechanics have nothing more than AC transformer welders (aka "Buzz Boxes"), and the electrode may be something like 7014 to get the high deposition rate and make those extra wide weave beads. Whatever the electrode is, the mechanics seem to run it fairly hot and get what appears to be a clean weld with good tie-in and no visible (at least in the youtubes) porosity or undercut. Whatever they are using, it seems to work well enough to hold their truck frames and other critical parts together.
On the Pakistani truck channel, there is also a youtube about the rebuilding of tie rod ends. This is in a truck repair shop. The mechanic opens up the worn tie-rod end and pops out the ball. He does some weld buildup on the worn surfaces, and uses what looks like a 'rugged' ball end mill chucked in a drill press to restore the spherical seat in the ball joint end. The drill press has the name "Solid" cast onto it, though it appears anything but. The ball end mill (or maybe just a large twist drill with the end lips ground to the approximate radius) chatters and the whole drill press shakes and groans. The ball is restored by some freehand work with a file in the lathe. The mechanic puts plenty of grease into the ball joint's 'cup' and seats the ball. He then places the spring and cover disc on the ball and uses a press to compress and hold things in place. Once has things where he wants them, he welds the cover plate back onto the ball joint body. Smoke from the grease pours out, but the job is done. Back onto a heavy truck it goes. Who knows how accurately the radius's and profiles of the ball and the socket it fits into on those ball joints really are after those rebuilding methods ? A few hundred Km on the Pakistani roads, rough as they are, will wear down any rough spots or sticking points in those rebuilt tie rod ends.
Frame repairs and lengthening are even wilder to watch on the youtubes. Frame channel sections are bent in one guy's shop on some ingenious home made hydraulic presses. If a frame section has a transition to it, layout is done on steel plate and the plate is burned to shape using a torch and freehanding it. The Pakistanis using the torches never seem to wear gloves or burning goggles (let alone a dark face shield). They work in their slippers or sandals. The burned edges of the plates seem nice and straight, and are slicked off with an unguarded large angle grinder by a guy with neither goggles nor closed footwear. The plates go into the hydraulic press and the mechanics in that shop do turn out some nice looking frame channel sections. Whether they use a higher strength alloy steel than ordinary structural grade is unknown. When the channel sections are braked to shape, delivery is often made by a young fellow with a three-wheeled motorcycle. This is some lightweight machine, not even as heavily built as an old Harley or Indian 3 wheeler. They load the channels onto the three wheeler any which way they can, and if had any suspension, it is bottomed out. The kid wriggles in between the channel sections and rides off to make the delivery.
Drilling holes in truck frames is done using a heavy electric drill motor with a Morse-taper spindle. A chain and a piece of lumber are used as a lever to force the drill into the work while the guys hang onto it. Re-riveting of truck frames is done by placing the rivets cold in the holes and heating the projecting shank with a cutting torch. When the projecting shank is red hot, one mechanic peens it with a heavy sledge. When he has peened and started to form a head on the shank, his buddy places a rivet snap on it and this is sledged to form the head. Bucking the rivets is done using a kind of jackscrew to hold the rivet snap in place on the factory-made head of the rivet. Working on truck frames, there are plenty of places to setup a jackscrew and snap to buck rivets.
Another beaut is a youtube of the installation of a transmission in a heavy truck. The youtube refers to this as 'with feet'. They meant it. A mechanic gets on his back under the transmission and raises his legs, pushing up on the tranny with his feet to work it in to place and get things lined up. When a transmission jack is used in other youtubes, it is an ancient thing worked by a screw and gearing rather than hydraulics. On the other hand, the same mechanics do have a very modern hydraulic all-terrain crane on hand and make good use of it. It is a study in contrasts to watch the Pakistani truck mechanics at work. No air impact wrenches, no air hammers, no personal protective equipment (PPE), working out on bare ground with plenty of dust and dirt to 'grind in the parts' they reassemble, not even a good welding shield. But, they do have a modern hydraulic crane at their disposal.
A whole other subject is the decoration and artwork on the Pakistani trucks. This seems to be at least as important, if not moreso than the actual condition of the truck itself. It's quite obviously a very different culture than what most of us are accustomed to. As I've said previously, I give the Pakistani mechanics and truckers a lot of credit for what they accomplish under their prevailing conditions.
