jerholz
Cast Iron
- Sep 24, 2015
- Dallas, Tx
I've been mostly lurking on this forum for several years now, and I guess I'm overdue for sharing pictures of my Hendey. I'm not much of a machinist; I got this in support of my aviation habit, and for something to learn on. I've had it for probably 25 years. I don't know much about it's history. The individual I bought it from apparently just purchased it to resell. Of course, it had issues. Turned out, the shaft under the headstock that holds the dogs for the forward/reverse on the feed screw was broken. After way overpaying for an incompetent repair, I found a local machinist that did the job correctly. It has another problem with the half-nuts. They won't engage unless you back the friction screws on the carriage feed way off. I hardly ever need to cut threads, so I've never gotten around to diving in to this one. I assume I'd have to remove the apron to fix it.
As you can see, it's pretty ugly. Once I got it working, I just started using it. It's been really useful over the years. When I bought it, I had never even heard of a Hendey lathe. It just liked it because it looked plenty heavy duty. It came with a three jaw chuck and a square tool post, which I promptly crashed into the chuck. I've since acquired the aloris tool post in the picture, a better 3 jaw, and a really nice Cushman 4 jaw. I don't have a taper attachment. I'm running it on an RPC, but it's a undersized. It will start the 3 hp motor OK, but if I try to engage the spindle at too-high a speed, the phase converter drops out. Sometime when I get some time for another project, I'll get a 7.5 HP motor and build a new RPC.
I'm hoping hendyman will drop by with the original history on it. Also, I'm curious about to know what "cl.823 compound" means.
Thanks.
Jerry
Thanks.
Jerry
