putteritis
- Dec 20, 2020
Looking for some help in identifying this item(s). Similar to a bench center but has a stud on the bottom and indexing head. When I purchased this it came with a second 'head' that has a worm drive and 360 degrees of marking on the gear that mates to the worm. While this second head will mount to the same bed as the index head it is nearly an inch taller and slightly offset so it does not align with the fixed center. The only markings on these items is 'S551' on the bed piece and 'PT4834S1' on the second head piece. Any help with what this item is actually called, who made it, where it is used, etc would be truly appreciated. Thank you
