Need Help Identifying Drill Press
Results 1 to 11 of 11
    Sep 2019
    Connecticut
    7
    Default Need Help Identifying Drill Press
    Hi everyone, I am new to the forum and just picked up a bench type drill press. It has a label on it that reads Triplex Machine Tool Co, NYC, no other identifying marks. It appears all original except the power switch. It has a single piece spindle with a Jacobs #1 taper that is not removable. I'd appreciate any and all info you have on the machine.
    Here are a few pictures - img_0150.jpgimg_0151.jpgimg_0154.jpg.
    Thanks for your help!
    Roger
  2. Likes cutting oil Mac liked this post
  3. #2
    Sep 2009
    Phoenix,AZ
    1,727
    2643
    430
    Don't be surprised if the thread is locked as that is a very cheap home shop piece. Single speed !! ,kinda a step up from the things they sold years ago where you clamped a 1/4" electric drill in.
    Apr 2004
    Shandaken, NY, USA
    4,266
    1132
    6718
    Triplex was a machine tool dealer in NYC years ago. The drill press, with all due respect to JohnEvans, appears to be a small "sensitive" drill press rather than a "home shop piece". These smaller sensitive drills were made to run at high spindle speeds and were often used in production drilling operations. Sigourney made a similar design of drill press, if I am not mistaken. This particular drill press could have been a WWII era machine tool, as quite a lot of these small sensitive drill presses were built for use in defense industries during WWII. Triplex was a machine tool dealer who sold machine tools from a wide range of manufacturers. I had a Burke Number 4 Mill with their dealer's plate on it. Triplex was located in the old "Machine Tool District" of Manhattan, an area of a few square blocks around Centre St, Lafayette St, and Canal Street.
  5. Likes Jim Christie, cutting oil Mac liked this post
  6. #4
    Nov 2006
    Southern California
    977
    5
    106
  7. Likes digger doug, Scottl liked this post
  8. #5
    Feb 2001
    Redwood City, CA USA
    4,942
    175
    882
    That’s no home shop grade machine. It is a Hamilton Sensitive Drill Press. I have a fancier one with a neat variable-speed rubber cone drive. My came from Mare Island Navy Yard when it closed.
  9. Likes digger doug liked this post
  10. #6
    Sep 2019
    Connecticut
    7
    Thanks so much for the info. Yeh, it doesn't seem like a "hobby" tyoe of press. It's massive and weighs more than 100 lbs. Does anyone know where I can find more info about the machine,such as motor and spindle specs? Also if there is a way to change the taper on the spindle so that I can use larger (1/2") capacity chucks?
    Thanks again for your help, it's greatly appreciated!
    Roger
  11. #7
    Oct 2005
    14,547
    Quote Originally Posted by reodds View Post
    Get another drill press to get to 1/2" capacity.
    I'll wager if you did get a 1/2" drill chuck on it, it won't have the speed slow enough, nor enough torque to drive it.
  12. #8
    Jul 2002
    Maryland
    4,403
    729
    603
    Hamilton Machine Tool Co. - Publication Reprints - The Hamilton Varimatic Precision Drilling Machine | VintageMachinery.org
    That document at the very least has some patent images that resemble your drill press. I only gave it a glance the first few pages. You'll have to have a closer look to see if it is relevant to yours.
  13. #9
    Sep 2019
    Connecticut
    7
    Thank you Sir, that document is invaluable, great information!
    Roger
  14. #10
    Sep 2019
    Connecticut
    7
    I happen to have a Buffalo Forge Junior, but it was modified by someone, and have to figure out hoe to power it. The lower pulley is no longer in place, and I'm not sure how to mount a motor to it that will be tension adjustable.
    Roger
  15. #11
    Sep 2009
    Phoenix,AZ
    1,727
    2643
    430
    OOOH !! Dope slap with egg on face !! That home brew belt guard threw me off I Think! I own a Hamilton ,just went out to the shop and dug it out . That is what yours is for sure. Wish mine was a vari speed. But can't complain toooo much as it was free. Had a Dumore which IMO was not as well made,as it did not have a quill but rather the table elevated.A bit of wear on the table slide surfaces equaled broken bits under 1/16 or so. I have drilled .25MM holes in mild steet with the Hamilton.
