Terry Harper
Cast Iron
- Sep 3, 2009
- Maine USA
O.T: Awakening the Beast Part II (Moving the 1928 Lombard Model "T" Dump Truck)
You may remember back in July I posted about awakening the 1928 Lombard model "T" dump truck. Well thanks to the amazing generosity of the Breton family we now have the 1928 Lombard model "T" dump truck tucked away in the Lombard shed along side the two steamers and the 10 ton gasoline powered Lombard.
Our adventure started Thursday night when I made the 2-1/2 hour drive down to Herb's. With the flatbed scheduled to be in Vassalboro at 8:00 am the next morning spending the night at Herb's and driving only a little over an hour made sense. As it was Herb and I were on the road at 5:45 am so we could be there in plenty of time to prep and awaken the beast.
Fortunately thanks to Paul's prep work the beast fired right up without a problem. After a bit of frantic tugging on the steering wheel and jigging back and forth we managed to clear the pole barn without crushing Paul's blueberry bushes. I can tell you.... it's near impossible to turn the wheels when its sitting still!
Here is the link to a video of today's adventure:
YouTube
Anyway, by 8:20 am it was loaded and on its way. Special thanks to Brandon our trucking guy! Unfortunately his GPS led him astray. He had set his GPS to follow the shortest route. However the "shortest" route was down a gated logging road.
Fortunately we found him and once at the museum we quickly had it unloaded and tucked away in the shed. This gave us a good opportunity to look the beast over. We have fuel problem which is either gunk in the carb or sediment and scale blocking off the line to the carb at the tank. The inline filter we installed earlier indicates that there quite a bit drifting around in the system. We also need to get the battery cables sorted out and the battery tucked away were its supposed to be. We tried out the dump body hoist but about 2,000 lbs of Lombard logging sled parts in the bed precluded raising it up too far. However, it worked excellent.
Driving this beast is interesting. It has essentially a heavy four speed truck transmission with the reverse blanked-off. Reverse and forward are handled by a lever down on the floor by the drivers left foot. It does give you four forward and four speeds in reverse. However, its an awkward reach to say the least. Meanwhile the lever for the hoist is a big reach over on the other side of the gear shift which would have a short person struggling to depress the clutch and work the lever. Lets just say its funky and neat and keeps the driver busy.
The track system is really cool. Tension is held by a big spring stretching clear across under the cab and pulling on fulcrums which apply tension to front sprocket bearing frames. The sprocket bearing frames are not mounted rigid to the chassis but can slide fore and aft via slides and gibs.
Anyway, our last event of the season is our "Living History" days on October 5th and 6th. Its also our biggest event.
In addition to all kinds of other stuff we will have the steam Lombard out running around as well as the 10 ton gasoline Lombard and the Lombard Model "T" dump truck.
Best regards,
Terry
YouTube
Best regards,
Terry
