J
J Tiers
Guest
Picked up an old small "sensitive" drill press for $5, figuring I would make it into a tapping guide. It is one of the old bench pillar type, small, 18 inch or so tall, clearly from maybe 1914 or so.
Pulley on top, place for a pair of guide pulleys on rear of casting, but no bracket or pulleys. Wildest ball bearing I have ever seen for the drilling pressure. The thing looks similar to the drill setup of the "Universal Pillar Tool" from an old issue of HSM magazine, but obviously is much older than that.
Anyhow, it has a jacobs chuck on it, which is a 0-1/4 or maybe smaller, with the 1902 patent date. Assuming they didn't bother after patent ran out, that puts it at about 1920 tops.
Anyway, that chuck is in near perfect operating condition, barring a little legitimate surface rust (a film). I decided to restore the thing instead of converting it, and I am tempted to pull off the chuck and not use it (I have another, assuming it will fit).
Seemed cool that the ancient chuck was still in good order. Don't want to damage it by use, now.
This would be about equal to a Jacobs #1 chuck, but is old enough not to even have a model number on it.
Anyone know if the old jacobs chucks used the same taper mount as the newer ones?
I have a #1A which looks, without having seen either taper, like the one on the drill spindle. Nice if it would fit, (and especially if I can get both off their tapers OK, that is maybe doubtful).
[This message has been edited by J Tiers (edited 03-18-2003).]
