Froneck
Titanium
- Dec 4, 2010
- McClure, PA 17059
Picked up a set true 8" 3 jaw chuck at HGR a while ago. One piece jaws and don't have the reverse jaw set. Have other chucks, not set true but the jaws on the chuck are correct for what I'm doing. L-0 back plate that looks factory installed.
This set true is not as most set true adjustments are. I have others that fit D1-6 spindle lathe that have 4 flat bottom large diameter set set screws that push against the back plate that has mounting holes larger to allow movement.
This chuck doe not have that type, only 3 adjusters. center of about a 4" long adjuster fits in a hole behind each of the 3 jaws. Adjuster accepts 3/8 hex wrench, has slight taper about 1-1/2 long and threaded 3/8-16
I loosened all 3 (very loose) since the item chucked was running .005TIR out, tightened the one behind the minus jaw and it moved + but it took quite a bit of force on the wrench to turn the adjuster so much force the 3/8" hex wrench would bow. I'm now .0009TIR out, probably good enough. However what am I doing wrong? Back plate is attached with at least 6, probably 8 3/8" flat socket hex head screws and didn't look like it moved. What is the proper way to adjust this type chuck?
