Odd threaded spindlenose?
Results 1 to 5 of 5
    Nov 2019
    SWEDEN
    Default Odd threaded spindlenose?
    Well i got this old lathe a few months ago but i just got it home. I have not been able to determine what make or model it is. I need a chuck backplate for this machine but people in a swedish forum have not replied so i am putting it here to.
    Unfortunatley my new mitutoyu caliper won`t show inches so these measurements is all metric.
    This is how my spindlenose looks.
    https://i.imgur.com/HE0GCyN.jpg
    There seems to be a slight taper to the thread since it differs 0,7mm from front to back (or just worn threads). The pitch is about 4mm.
    This is a few pics of the machine from my other thread.
    Old lathe - Album on Imgur
    Jul 2004
    Houston, TX USA
    30,449
    Measure it up, make or have made a "duplicate" so you have a plug gauge to use when making (or having made) a back plate
    Describes MANY old lathes
    About the only STANDARD threaded nose lathe makers used was their own idea
    The taper could be wear or intentional - or some of both
    Feb 2006
    Indiana
    13,013
    698
    3965
    I noted that the Swedish language thread chart on the lathe seems to indicate that the lead screw has an inch pitch and you need a 127 tooth gear to cut metric pitch threads. That will require special effort to learn the procedures for threading.
    An inch lead screw on a lathe in Sweden does not prove that the lathe was made in England or other inch-using countries. My 1969 Volvo 164 had normal USA standard nuts and bolts except on the German-made brake and steering components, which used metric fasteners. It took two sets of tools to work on that car.
    Larry
    Jul 2004
    Houston, TX USA
    30,449
    ON EDIT OOOPPPPS - not paying close enough attention to posted dimensions. Please disregard comments below - thanks Larry!
    And with that in mind, perhaps the spindle nose is a well worn 1 1/2 - 6 Imperial
    Probably possible (even in Sweden) to acquire a standard 1 1/2 - 6 hex nut to see if it fit at all
    Apr 2013
    Damascus, MD
    1,485
    4288
    849
    I would suggest measuring the threads with the three wires method to see if it is indeed worn, or is tapered.
    Paolo
  6. Likes James H Clark liked this post
