M.B. Naegle
- Feb 7, 2011
- Conroe, TX USA
This is a Brown and Sharp Horizontal mill we have at our place. I think this machine's been in service it's whole life. It's seen a few upgrades but I'm thinking about overhauling it someday. I'm wondering if anyone has info on it:
1. In a modern shop, what jobs can this machine do? The machine has No Y movement other than how you space out the cutter. The only jobs I can see this puppy doin is plaining metal with a 6" long or so cutter or doing jobs with a special jig that'll hold your part exactly where it needs to be. The most recent job we've used this machine for was cutting slots with the cutter shimmed to the right space.
2. The Z movement assembly has been replaced. Does anyone have a picture of how this systum originaly functioned? My guess is that it mounted to the spot where we have the feed moter mounted now.
Overall view.
Information
I'm going to redo the motor mount configuration with the motor bolted to the back of the base with the shaft pointing towards the machine.
Back view. Obviously the feed motor is aftermarket. There's a pully on the flywheel shaft where I think the Feed motion was originaly taken from. The new system's nice though and will stay (though it might get moved to a more secure location. The control box will be routed to the front of the machine). We also plan to put a good enclosure around the flywheels and belts. Osha will be so pleased.
The Z movement I was talking about. The hub that the aluminum block wraps around has incremental lines on it but they're covered up. If I have to fabricate my own systum I'd like to route the handwheel underneith the bed towards the front.
View of the work area. Only a single slot! Lots of machinests didn't like this and put all kinds of threaded holes in the bed. These'll get filled eventually.
Overall view.
Information
