Old Lathe ID help
Results 1 to 16 of 16
    Oct 2020
    33
    Default Old Lathe ID help
    All,
    I've just acquired my first-ever lathe, and would like some help figuring out what it is.
    I forgot to take more pics in the daylight, but will post additional shots tomorrow.
    I cannot find any make or model number. The only major meaningful marking appears to be "PATP Feb 15 1887" on the back side of the bed.
    EDIT: A quick search yielded a patent for that date for W. F. Barnes, and the illustrations in the patent application look eerily similar, though my eyes aren't exactly trained to see the important details here.
    In any case, hoping someone here can elaborate on exactly what this is.
    Thanks very kindly!
    Last edited by Philosophy Guy; 10-28-2020 at 12:18 AM. Reason: Found a patent that matches this?
  2. Likes Limy Sami liked this post
  3. #2
    Apr 2007
    Minneapolis, MN
    1,628
    125
    685
    W.F. & John Barnes, Rockford Ill.
    Rob
    Oct 2020
    33
    Thank you!
    Any idea what model this is?
    EDIT: Maybe the 4 1/2? Here is the plate:
    Jul 2007
    Stratham, Cow Hampshire
    4,458
    518
    1875
    4-1/2 in a later "benchtop" version. The legs are not exactly like any I've seen but are probably original.
    Earlier versions of this lathe are told by a "bead edge" on the major headstock and tailstock casting. This lathe I would put to early 20th century - post grid power.
    The nameplate is the same nameplate used on the front of the usual left floor standing leg. I've not seen this location before.
    The bead edge barnes lathes were a generation earlier. (1880s)
    Joe in NH
    Oct 2020
    33
    Thanks very kindly!
    I'll probably be filling this thread up with questions as I tear this thing down and rebuild it.
    For starters, what is the best lubricant to use on reassembly? I'm doing it a couple pieces at a time to avoid misplacing/mixing up parts. The compound and tail stock are all disassembled and cleaned up. Assuming it's going to be either grease or oil, and maybe different for different parts, but just trying to get a primer on this.
    I'm already in heaven getting into this thing.
    Thanks very kindly all!
    Feb 2006
    Indiana
    13,485
    760
    4327
    Quote Originally Posted by Philosophy Guy View Post
    ...I'll probably be filling this thread up with questions as I tear this thing down and rebuild it...
    Now that you know the ID, start a new thread with the ID in the title. It helps future readers who search for posts about that kind of lathe. The old title is useless in that regard.
    For instance: W.F. & John Barnes, Rockford IL 4-1/2 Bench Lathe
    Larry
  8. Likes rjs44032, ClappedOutBport liked this post
  9. #7
    Oct 2020
    33
    Thank you. That makes sense, and will do.
    Just saw the sticky on what kind of pics to post here for ID purposes, so I'm going to post up some more today, together with some measurements, as I'm now seeing a number of cases in which the #5 has the 4 1/2 plate on it.
    Thanks again.
  10. #8
    Jan 2007
    Norfolk, UK
    20,684
    16108
    16539
    That looks a nice one - take care taking it apart - to the uninitiated some machine tools have mechanical ''twists'' not seen elsewhere.
    Rule #1 through 10 BE VERY CAREFUL WITH HAMMERS & LEVERS
  11. Likes Hudson liked this post
  12. #9
    Apr 2006
    Manchester, England
    9,009
    1455
    5952
    Quote Originally Posted by Limy Sami View Post
    I only had two rules for dismantling machines Sami -
    1) Don't break anything.
    2) Don't lose anything.
    At the risk of offending our American colleagues can I just say I cringe whenever I read the expressions " tear down " or " tearing down ". It gives the wrong impression.
    Regards Tyrone.
  13. Likes dundeeshopnut liked this post
  14. #10
    Oct 2020
    33
    Thank you, gents!
    And if it makes you feel any better, I also don't particularly care for the phrase, "tearing down," for the same reasons.
    Perhaps "gently disassemble with awe and humility" does a nicer job of expressing the sentiment.
    And yes, it seems, aside from a little cosmetic wear here and there, to be in very good condition.
    All the tools are still with it, the gears are immaculate, the spindle turns absolutely silently with no perceived slop anywhere, and while there is a lot of crud on everything, the carriage, slides, and tail stock run butter smooth.
    For all its age, I've had no issues (thus far) taking things apart.
  15. #11
    Mar 2020
    CANADA
    Quebec
    103
    223
    73
    Quote Originally Posted by Tyrone Shoelaces View Post
    Regards Tyrone.
    I guessing the expression "blow it apart" would be in the same list?
  16. #12
    Oct 2020
    33
    Okay, more pics as promised. Hope these are helpful. My apologies for the lighting. Wasn't able to take any during the day. One thing that came up as a question mark was the bed length. Not sure if that makes a difference between the models, but this one has a bed length of 40".
    Now to the pics:
  17. #13
    Apr 2020
    Ohio
    630
    569
    194
    3rd story window will disassemble anything quickly. Man dragging my SB16 up there to rebuild the headstock was a PAIN!
  18. #14
    Apr 2006
    Manchester, England
    9,009
    1455
    5952
    Quote Originally Posted by dundeeshopnut View Post
    I prefer " persuade " it apart. You start out with minimum force and gradually increase the level of force until you have a successful conclusion.
    Regards Tyrone.
  19. #15
    Jul 2007
    4,458
    518
    1875
    My very standard Barnes 4-1/2 (legs and Velocipede) is 40 inches bed. I'm not aware that Barnes made any other lengths of the 4-1/2 machine.
    My very standard Barnes 5 (legs and Velocipede) is 51 inches bed. Barnes DID make other lengths, particularly at the end of production, to include a "Gap Bed" style lathe that would turn up to (say) 15" diameter for a short distance past the head stock.
    And of course there was the larger No. 6 and it's variants.
    Generally the 4-1/2 is the most common. It was the cheapest full screw cutting lathe, and commonly bought by off-grid users. It could be ordered in the morning at the local telegraph office, and would be delivered nationwide THE NEXT MORNING at the local railroad depot in two possibly three wooden crates. And this in 1890! Amazon is nothing new!
    For every two 4-1/2s in the world I would estimate one No. 5 - price the original driving factor. For every five 4-1/2s in the world I would estimate one No. 6 or its number variants. The large machines are considerably rarer.
    More written up on the Barnes variants at Tony's most excellent site. Barnes Lathes
    Good luck!
    Joe in NH
  20. #16
    Oct 2020
    33
    Awesome! Thank you all so much!
    I'll be starting a new thread with specific questions as I work through this thing.
    Cheers!
