old lathe - open head with all gears and no pulleys - who made it?
Results 1 to 8 of 8
    Oct 2006
    Virginia
    54
    15
    28
    Default old lathe - open head with all gears and no pulleys - who made it?
    I ran across this online and thought someone might know what it is. Seller doesn't provide much info. Here's the ad in case someone wants it. Facebook Marketplace: Metal Lathe - Tools - Pfafftown, North Carolina
    Feb 2005
    1,198
    959
    1034
    It looks like a Greaves Klusman lathe that was a flat belt drive that someone was converting to gears.
  3. Likes bl00 liked this post
    Jun 2001
    St Louis
    18,083
    1927
    3062
    It looks like the "design" is similar to a QC box, intended to have that shaft at the top driven, and then the gear setup in the frame seen on the biggest gear is supposed to be moved to the appropriate spindle gear.
    Lacking at the moment is the locking means for the moving lever, any visible drive means, and, quite probably, "a clue" on the part of the owner or conversion designer.
  5. Likes bl00 liked this post
  6. #4
    Oct 2019
    NICARAGUA
    106
    41
    I dont know about clueless, it looks pretty cool to me. Some of us get sick, or die in the midst of a project like this, then someone lists it for sale. He has some good work in all those gears. Probably noisy, though.
  7. Likes bl00 liked this post
  8. #5
    Jul 2004
    Houston, TX USA
    30,249
    I'd guess Le Blond from tail stock and little lever down low left end, though maybe older than this 1911 example. A lot of effort went in to the noise making mod
  9. Likes Paolo_MD, bl00 liked this post
  10. #6
    Jan 2014
    Coventry RI
    1,150
    1384
    915
    Just a guess, but maybe someone was modifying it for some high lead application where the spindle would be driven at a slow speed by the end gears???
  11. #7
    May 2011
    New Jersey
    2,420
    212
    1304
    Not to sound crass but that looks like a great way to lose parts of yourself.
  12. #8
    Jul 2004
    Houston, TX USA
    30,249
    Quite the oldie - I see the carriage is the Rise and Fall design
