I found an old motor, that hopefully can be made operational to run my line shaft. It's of the period and It's a pretty neat piece I think. A Westinghouse Electric Type AR 5HP single phase constant speed. 1725 RPM, 460 Frame, 515 pounds with the base. The thing is massive for a 5HP. Rated for continuous use at 5HP with a 40 degrees C temp rise max. Runs pretty cool with all that mass. Bearings seem fine, spins smooth and seems tight. Will need to check the brushes and clean the commutator. I'm tempted to just wire it up but probably best to clean it first. So this will be another project to add to the list.
nice brass end cap
Two dates on the bottom of the tag both 1912. not sure if these are patent dates or if one is a date of manufacture.
nice brass end cap
