Old Reed&Prentice
Likes Likes:  0
Results 1 to 8 of 8
    Jun 2020
    Minnesota
    70
    32
    42
    Default Old Reed&Prentice
    00x0x_apnlxfpa6bwz_0t20ci_1200x900.jpg 00x0x_dilyhvgt2uaz_0t20ci_600x450.jpg
    I might look at this lathe but am wondering what info I can gather here before I go.
    Can anyone tell me what the top rpms of this machine would be,
    Also any idea of the size? Seller doesn't know.
    He says it's a flat belt drive which I'd guess predates the chain drive RPs.
    I don't need a real modern machine but I do want one that will turn 1000 rpms or so.
    Thanks for any info.
    Jul 2004
    Houston, TX USA
    31,969
    You are less than half way there
    18 to 432 in 1930
    Last two entries here from 1935 - which shows the later "L" type spindle nose - that your example lacks
    Reed-Prentice Co. - Publication Reprints | VintageMachinery.org
    have fun
    Jun 2020
    Minnesota
    70
    32
    42
    Thank you.
    I guess I'll pass then.
    Virginia
    19,112
    7561
    11682
    Quote Originally Posted by Ultradog MN View Post
    Take better fotos. Frame them. Hang 'em on the wall. You and Reed-Prentice have done yer duty.
    Now go find a newer lathe you can set on the floor and make chips with.
    That simple.
    Jul 2008
    South Carolina
    1,010
    583
    695
    I'm fairly certain that is a chain drive model. Also known as a "silent drive"
    Mine is a little newer but has the same layout. That long end cover has the chain drive behind it.
    Hodge
    Sep 2008
    2,436
    1793
    1524
    I have a friend who has a Reed Prentice, the ways by the chuck are very badly worn, I would check the ways before anything else.
    May 2013
    georgia
    24
    Keep us posted if you decide to follow the machine home! I am parting out a similar machine and may be able to help with some missing parts or damaged gears
    Dec 2016
    New York
    710
    9
    253
    I have the same machine in the 14 x 30 size and i love it. Mine has very little wear and works great. Headstock has spur gears so it's quite loud but it is a very stout and accurate machine.
