An old style metric micrometer, and an off brand metric micrometer (McGrath)
The old style is really a clunky old style.
It is metric, and actually seems to agree very well with my newer metric mics, at least for small measurements.
Oddly, the dial on it is marked backwards, so a measurement of 0,39mm is actually shown as 0,12mm on the dial as assembled. The screw is RH, and advancing it reads increasing numbers on the dial, as the space between anvils decreases.
It is possible that the dial was to go on the other way, although I have not checked to see if it can be reversed. Doing that would seem to make it very hard to read.
It seems to be marked on the reverse of the scale as "Columbus" or "Columbia" followed by indecipherable, and under that "Indianapolis" (both in all caps). You have to remove the scale to read all the text.
Backside of the unit. I have no clue as to whether this is an earlier unit, or a later unit that for some reason is made in this style, either because that suited the use, or because the market was very conservative.
It being metric is another interesting factor, as metric mics have not been exactly thick on the ground until more recently, at least in most industries and usages.
The other mic is also metric, and standard design. The oddity in its case is just that it is marked "McGrath St Paul" apparently as the maker. I have never heard of that as a maker, and I wonder if it may be a dealer's name who had mics marked with their name.
