OT?-Friction Crane Boom Not Lowering - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 69
  1. #21
    Feb 2013
    Houston TX
    3,839
    16
    1911
    Spent 5 minutes with it today, hung a bit more weight on the heel. 15' of 14x54, cables started to jump a little, bit still no boom down.
    Didnt have a chance to lube up the cables but that's next. May add another I beam on there as well
    Sent from my SM-G965U using Tapatalk
  2. Likes JHOLLAND1, DrHook liked this post
  3. #22
    Aug 2005
    Tucson AZ
    6,370
    9591
    3001
    Ooooooh no. You have a bent vertical tube at the top of the heel. This what P&H, I believe, called "Tube Lite" boom. It was welded and the entire weldment was then heat treated,(probably stress relief) as a unit. Get real serious advice on that repair, maybe find an old P&H man. Around the farm, Ok. Anything for hire, have something in writing from some kind of competent person. This boom should definitely be lowering here so investigate the boom hoist rope and all sheaves. Something is giving too much resistance.
  4. #23
    Aug 2003
    port allen, louisiana usa
    1,729
    473
    407
    There must be something not releasing in the boom circuit.. That butt section should lower.. Are you sure the brake is opening on boom down and that the boom dog is released fully? The boom drum will rotate to boom up right?.. I would be careful adding more weight to that butt section.. If you distort it, you may never find another....Ramsay 1
  5. #24
    Dec 2008
    minnesota
    159
    26
    161
    Matt:
    I don't think you are likely to harm your boom base section by carefully
    adding some more weight.
    However; if the boom hoist clutch drum and shoes are not clean and shined up;
    they can drag enough to prevent the boom from lowering.
    Check the drum surface for dirt, rust, or stickyness from oil or brake fluid.
    When using these machines we often have to tighten the clutch shoe settings
    to get it to lift a heavy load. Then after the machine sets unused for weeks or
    months; we need to back off that boom hoist clutch setting to get the boom to lower.
    It is the hex link between the bottom of the two clutch shoes.
    petersen
  6. #25
    Dec 2008
    minnesota
    159
    26
    161
    One more thing:
    If you can lightly "feather" the boom hoist control WITHOUT THE BOOM RISING ;
    just sit there with engine running and shine up that clutch drum.
    That clutch drum must slip freely by those shoes for planetary lowering.
  7. #26
    Aug 2003
    1,729
    473
    407
    Quote Originally Posted by tdmidget View Post
    It was once my job to replace bent lacing on crane booms... I think the rule was if you had three bent in a row, you had to replace all of them..I had to grind the old one out and weld the new factory spec lacing in place.. Both of ours had tube lacing.....Had to grind the old one out carefully so as not to get into the main chord then grind a new lace to fit and sew it up with 7018.. No torches used anywhere..If the lacing was flattened, it was flattened cold... Retirement is so nice.. Cheers Ramsay 1
  8. #27
    Aug 2003
    1,729
    473
    407
    Quote Originally Posted by petersen View Post
    Matt:
    petersen
    We use to use Fuller's earth in the frictions and brake bands...They bite when you want them to and hold but they still slip when you need it as when running a clamshell bucket....I had it in a small squirt bottle like you see in restaurants for ketchup and other things.. Kept it in the engine room.. Ramsay 1
  9. Likes tdmidget liked this post
  10. #28
    Aug 2005
    Tucson AZ
    6,370
    9591
    3001
    Quote Originally Posted by ramsay1 View Post
    We did the same. If oil gets on the drum it will cook into a sticky goo that will give you fits.
  11. #29
    Aug 2003
    1,729
    473
    407
    Our machines were air over mechanical so if something started leaking, it was usually a roto chamber or air cylinder...One thing we did have trouble with on the linings was dampness from diamonium phosphate fertilizer.. It would make it impossible to hold the 5 yd bucket we dug the product with... Had to take comet cleanser in the morning with water and get it out or we could not do the day's work....usually once the brake dried out, more fuller's earth was applied....Ramsay 1
  12. #30
    Dec 2012
    AUSTRALIA
    2,263
    10
    687
    When I got my current crawler crane,I looked for the simplest setup I could find.....nothing but external bands ,all worked by a self servo mechanism.......Ive had a few hairy moments ,if the drums sit for a while and get rusty ,first they grab ,then as the rust powders they slip under load until they shine up ,then all works as intended.....Ive had P&Hs and Northwests,both use brake fluid ,never again.Air controls are better,but you still have rotating seal elements.....If I was young again,I would convert to hydraulic motors,but no point for what time I have left.
  13. #31
    Aug 2003
    1,729
    473
    407
    Quote Originally Posted by john.k View Post
    Air over is always best as far as I am concerned.. American, Bucyrus Erie, Lima, and other air over, all you have is air that leaks.. Just fix what ever is leaking and keep on running....On the rusty drums, I once saw a link belt pull the lining off the rivets on the band on a boom brake.....Good thing the operator was good as he stopped everything before the boom fell....It was a 108 Link Belt...It was a new lining and it had seized to the drum by rust.. Cheers; Ramsay 1
  14. #32
    Feb 2013
    Houston TX
    3,839
    16
    1911
    Sorry for the delay in replying guys.
    Last few weeks been busy, started working full time, was finishing exams and last Friday I graduated school.
    I think I'm going to throw another beam on the boom heel, it's got about 1000lbs hanging on the end of it right now. I was gonna add about another 500 lbs, as when I was last working with it, I saw the boom cables twitching and looking as if they were trying to move.
    Also going to go and coat the cables with oil and grease.
  15. Likes Paolo_MD, 4GSR liked this post
  16. #33
    Jul 2004
    Houston, TX USA
    30,024
    Congrats on that Matt.
  17. #34
    Aug 2003
    1,729
    473
    407
    Quote Originally Posted by alskdjfhg View Post
    Soak your ropes with oil.. As ropes age and as they run, the original lubricant works its way out from the center....Seems there is something preventing the boom drum from rotating in the pay out direction.. That thing should not be that hard to boom down....I've see sheaves frozen in inner and outer bales with rope sliding over them and still allow the boom to raise and lower..Something is not right for sure.. Ramsay 1
  18. #35
    Feb 2013
    Houston TX
    3,839
    16
    1911
    Quote Originally Posted by johnoder View Post
    Thanks John. Looking forward to not having school and making more money.
  19. #36
    Feb 2013
    Houston TX
    3,839
    16
    1911
    What else could it be besides rope friction? Booms up fine.
  20. #37
    Aug 2003
    1,729
    473
    407
    You have something preventing the boom drum from paying out...If your boom lowers through a formsprag, it could be something there not allowing the drum to turn in lower position.. If the brake is fully open and the boom hoist ratchet is free, then it should lower with the weight of the butt section....Ramsay 1
  21. #38
    Feb 2013
    Houston TX
    3,839
    16
    1911
    When I took the boom off, I had 70' on it, didnt have any issues booming down
  22. #39
    Aug 2005
    Tucson AZ
    6,370
    9591
    3001
    With the dog out and the brake band loose, it should come down with just the heel weight. Is the rope wound over itself such that it is pinched by a later wrap by some chance?
  23. Likes muckalee liked this post
  24. #40
    Aug 2012
    California, Central Coast
    3,729
    2193
    1471
    How long ago? Been sitting so rust build up, either in clutch mechanism or pulleys and rope or all of above. Get the garden sprayer with diesel/motor oil mix in it and spray down the rope and pulleys . Let it soak in.
