ot---gundrilling with french vanilla
JHOLLAND1
Titanium
Oct 8, 2005
western washington state
so--topic of this thread is drilling 7/16 inch bore thru 35 inch long Moore jig borer spindle--thru which draw bar will be inserted to seat iso 30 tooling ground to Moore taper
spindle is R-60 hardness
my first attempt using Botek 27 inch length gundrill and sulfulated squirt can cutting fluid was characterized by 2 inch penetration at which point the carbide drill tip exploded--fragment analysis demonstrated no injury to 4 facet cutting tip but binding of flank resulting in twist breakage at silver solder junction
so--I tuned a wagner 700 psi airless paint power unit and milled 3/8 inch
window in side of drill driver hub--which seats in morse taper 3/4 inch solid socket-- a momentary foot switch pulses cutting fluid to drill
drill requires snug delrin bushing positioned 1/2 inch from spindle entry
the real discovery in this undertaking is use of espresso mix french vanilla concentrate diluted with tap water--this fluid has thus far allowed spindle penetration of 16 inches with no adverse consequence other than minor expected cutting edge dulling---I purchased 20 identical drills anticipating destruction of 19 ------------- each new drill is good for about 2 inch depth at which point chirping begins as dulled cutting edge searches for purchase--and immediate removal from service--I will regrind later on walter 8 axis unit
so analysis of french vanilla extract must incorporate minimum of 35% ethyl alcohol --statute requirement of FDA
to this the flavor chemists at Beck's add propylene glycol --
I had on hand a dozen 5 gallon containers of mostly empty Beck's concentrate
of variety of flavors--to which tap water was added
drill progress thru R60 steel is two inches/hour --flavor mixed fluid allowing increased progress and reduced breakage
so is this amateurish happening a legitimate breakthru in metalworking fluids--to truly clean and green?--likely not, but for the moment methodology facilitating a formidable undertaking:)
YouTube
That looks like a real mess. All the sugars and other ingredients in that stuff will become a nightmare to deal with as it begins to deposit and build up in those hard to reach areas of the machine. Even the not-so-hard to reach areas will be a constant battle. Then your shop will be overrun with all the little critters that want to dine on the residue. You might be better off sourcing the active lubricants you want individually and mixing them yourself
agree with the mess comment, but----shop rats keep invertebrate population under control:)
I think you're quite mad. Which is the best sort of mad.
Not at all clear how you decided on the vanilla extract, but I imagine there's a large number of folks here who would have suggested bacon fat instead. With both options you could have opened a Diner and Malt shop with whatever was left over.
Clever little rodents didn't set out to make enemies, but unfortunately, various "invertebrates", bacteria, and viri return the favour. Not a cycle one wants to disregard.
Enter the "glue trap", as it catches the newbies too low in mass to yet trip a reg'lar trap onct mama has done so, teats removed from the scene.
Bait? Salvaged bottle top of ordinary water, one popped pop-corn kernal. Used in pairs, even the Evil Kneival wannabees take the glue.
PS: More than one way for securing those tapers at the face. No drawbar involved.
To be honest, I'd use a high sulfer or high chlorine, neat cutting oil. Those seem to work acceptably with carbide inserts on high-hardness steels when I'm not cutting dry.
Around 1961, I saw in an old book a suggestion that oil of wintergreen (AKA methyl salicylate) is useful as a cutting fluid for hand engraving silver. I tried it and it probably did help. Plus, it smelled great. Now I wonder what Torani sugar free vanilla syrup coffee flavoring would do in that application.
Larry
IF... one were to be modifying at the face of the spindle for a non-drawbar retention system.. holes would want threaded - a challenge, to be sure. But they'd also be right SHORT holes, served more easily with solid carbide, and not as large in diameter.
Is the material too hard for HSS,then?
Not really. There is HSS, there is "other" HSS , there is even not-really-HSS for scarcity of Iron in it. British invention. For knives and forks, initially.
Solid carbides are just cheap, available, and damned STIFF. Good at their job, IOW. Especially for SHORTER holes a face-retention rig would want 'stead of a looooooong drawbar overly subject to stretch or twist fail in any case. Sub 7/16" and mebbe 24" long, wrench to threads?
So why bother?
Well. d'you know "mountains"? Meant to be climbed. Because they are THERE.
Deep holes, hard material? Much the same.
I mean, c'mon?
Denis is an MD. He can't just go off deep-hole drilling a live human's work-hardened arse for insertion of brains. Got's to experiment on passive metal.
First.
Ive got to ask, why did you not contact a gun barrel manufacturer and have the material drilled for you in a softer state, then harden and ream/hone the inside to size? Barrel makers routinely drill 30" long holes a lot smaller than 7/16". I think there is one in Wahington and several in Montana probably in driving distance.
the handshake
for millennia opposing digging teams dedicated to tunneling exchange handshakes upon breakthrough
similar celebratory satisfaction was experienced as the 33 inches of R60 drill path was completed
major concern regarding path drift at breakthrough--no destruction of carbide drill tip occurred--estimate coaxial disparity at 10 -12 thousandths
drill sequence required 18 inch penetration from splined end and 15 inch from taper socket
drawbar is 36 inch 7/16-14 all thread--some resistance to passage of rod was remedied by lapping with application of valve grinding cmpd to all thread and lapping at 400 rpm---drilling occurred at 80 rpm
questions asked why I did not contract out this job---well, metal working disciplines are voyages of discovery--and this event qualifies
spindle hardness of R60 would likely result in job turn down by deep drill shop ---reason--no gun drill maker recommends drilling metal of hardness beyond 50 Rc
my drill cost was $300 usd--and I will sell the majority of bits after I regrind
out of 20 new drills 17 were used--3 totally destroyed--remaining 14 suitable for regrind
an important refinement in method evolved--retracting drill every 1/4 inch of penetration, purging cavity with compressed air then filling cavity with CRC foam thread cutting compd followed by repeat drill cycle using water
CRC product formed emulsion which adhered to metal and minimized tool breakage--also faster penetration at times like cutting delrin--
