ot----secrets of Moore jig borer B-18 - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21
    Oct 2005
    western washington state
    3,507
    2206
    3415
    Default single point lift------B-18 jig borer
    Moore notes in manual for G-18---predecessor of B-18---eyelet in
    top casting of G-18
    thread is 1 in-8tpi so I installed bolt, washer, jam nut and lift sleeve/shackle and moved borer a few feet--no problem
    single lift point on any precision machine is rare---but this unit is perfectly balanced and the 1.75 inch thread engagement in machine frame appears adequate
  2. #22
    Aug 2010
    Medina OH
    1,666
    88
    670
    Quite an undertaking. I love my Moore #3, and don’t understand the fuss most make about them. They are fantastic machines, quick, versatile, and will mill better than any R8 Series I that I have ever run.
    I sure would love it to have a 30 Erickson quick change spindle.
    My Moore is a 60’s vintage, and when working on it the first thing that struck me was the amount of aluminum, or some form of alloy, that they used.
    The second is the incredible quality.
    When I bought my Moore I called Moore to ask about parts and service. The gentleman was very nice, helpful, but somewhat teasing in the fact that they would help but I couldn’t afford it. He also said I was about 20 years late. Last time they were acquired they cleaned the facilities. He said several NOS Moore #3’s along with TONS of parts were dropped in scrap hoppers. I think he said they filled several of the semi truck sized.
  3. Likes JHOLLAND1 liked this post
  4. #23
    Oct 2005
    3,507
    2206
    3415
    Quote Originally Posted by Fal Grunt View Post
    my initial plan was to grind spindle socket to 30 erickson-- with drawbar
    given the precision of the factory taper socket there is little liklihood
    my grind effort would yield axial and radial nominal tolerance equivalent to oem
    so--current plan is to grind new iso 30 tooling to Moore socket half angle of 7 deg 56 min 56 sec--
    the B-18 spindle will still require gundrilling to metric 10 mm drawbar clearance--
    and if I come across bargain moore tooling--the machine will function
    as built with modification of square thread seating tool in taper will require amputation with toolholder tapped for 10 mm drawbar--this should allow
    bidirectional tool rotation without backout
    also planning on adding servo motor cog belt to hand crank quill feed for full 3 axis motion
    we will never again witness this level of quality in US sourced tool
    Attached Thumbnails Attached Thumbnails 100_1235.jpg   100_1236.jpg   100_1237.jpg
  5. #24
    Oct 2005
    3,507
    2206
    3415
    Default taper toolholder grinding
    not much available on this topic as small shop undertaking--even oem's
    in videos do not disclose much
    a few points connected with conversion of iso 30 taper tooling to Moore jig borer compatible--
    my initial attempt at reproducing 7.95 degree taper of Moore tool shank was workhead swivel--this did not allow use of tailstock dead center--a necessary
    feature for best outcome
    I am using iso 30 er 32 toolholders--new--good chinese quailty
    my initial error was gripping 30 toolholder by ground circumferential od and
    using that for indicated reference for all other metrics--mistake leading to egg shaped taper grind---I then chucked carbide 3/4 end mill for gripping in collet and 8 in Buck adjust tru--better but the 8 in Buck was replaced with 6 in Buck with good --less than 0.001 in runout
    32 er collets require nut torque of 80 lb/ft--important to maintain part to part repeatability
    workhead was set back to 0 degree pinned position and swivel table rotated 7.95 deg as indicated by Moore 1/2 in toolholder indicator sweep
    then 30 factory toolholder gripped in 6 in Buck and tail center engaged
    wheelhead was swung 7 deg to allow way cover clearance during x axis traverse
    pics show initial workhead swivel followed by table swivel
    video---Moore B-18 tool socket documenting large relief band between upper and lower ground engaging surfaces--also note internal thread holding Moore tool in taper
    YouTube
    Attached Thumbnails Attached Thumbnails 100_1241.jpg   100_1243.jpg   100_1246.jpg   100_1249.jpg   100_1250.jpg
  6. #25
    Oct 2005
    3,507
    2206
    3415
    Default taper toolholder grinding-- a few thoughts
    so I am using 30 taper iso tooling from China--good quality and holders are factory balanced to 20K rpm
    to balance these holders an eccentric circumferential grind appears to be employed rather than typical drill pecking for spot balancing--my initial mistake was to grip holder in 3 jaw with contact occurring on ground band just above threads--constant inconsistency with runout always 0.002 in minimum
    when ground carbide rod 3/4 in was used in 3 jaw runout dropped to no more than 4 tenths--tailstock engagement increased runout a couple tenths
    so my first 30 toolholder grind was executed with holder gripped by 3 jaw just above nut threads--predictably the result was poor
    second attempt on new holder relied upon clamping carbide rod in er32 collet and tailstock dead center
    nice result with dykem blue confirming consistent contact with Moore taper socket engagement --no socket wobble --cannot calibrate runout until Moore spindle is drilled for drawbar--3o taper tooling requires 12 mm drawbar
    process conclusions---
    big diameter carbide rod in toolholder tightened to maximum torque with adjust tru tuning gave 4 tenths runout
    30 iso taper is 8.30 degree while Moore taper is 7.95 deg--this is table setting
    small end diameter is the metric used to gage grind progress--most importantly--3 to 5 % additive nominal dimension measurement must to used as endpoint using measurements derived from Moore toolholder
    if you use as endpoint measured or blueprint values as spected by Moore --
    overgind unusable tool will result
    reason is spindle socket measurements are all but impossible to obtain--but this is a 40 year old tool with significant use and socket dimensions will be expected to be greater than oem
    small end diameter of Moore holders 0.615 in --my measurement
    when I ground to 0.640 in the 30 tooling provided excellent fit no wobble--and if necessary --additional metal for removal
    small end taper measurements are all that are necessary---if grind angle is correct the big taper end will seat in satisfactory fashion--as verified by tool blue
    pics illustrate Moore holder on left, overground bad result adjacent, good ground 30 holder and unground oem 30 holder right
  7. #26
    Oct 2009
    Oregon
    4,006
    4300
    2017
    Get's a bit damp in your shop eh?
  8. Likes JHOLLAND1 liked this post
