OT-Split rims
Results 1 to 17 of 17
Thread: OT-Split rims
    Mar 2007
    On Elk Mountain, West Virginia, USA
    2,124
    941
    739
    Default OT-Split rims
    I run, have run, or plan to run a few old trucks with split wheel rims. I am all battened down and ready to be told that these rims are suicide waiting to happen, but in my own carefully considered folly, I inspect them carefully, take care that everything is properly engaged and only inflate them wrapped in chains (have not made a cage).
    I have a lovely 12 lb duckbill hammer and a good collection of the special prying tools or the rims, the two-piece unsplit, the two-piece split, and the three piece. The only kind (that I know of) that I have never cracked, is the kind my 1966 Dodge 400 came with, that splits in the middle of the flat center section. That is not today's question, but in case (I ever have to deal with one I would not mind knowing how to split those, too.
    My question is, is there a trick to getting the dang tire-and-tube-and-flap assembly off the rim after the lockring is removed? I suppose they slide nicely off a recently painted heavily talced rim after having been on for a week, but the ones I usually deal with have been on for 10 - 50 years and the rims are rusty. I have gotten quite a few off, but it is a struggle. Destroying the tire and tube is an option, since 6 lug x 7 1/4" BC deep-dished rims are unobtainium while tires and tubes are merely unaffordable, but I'd rather learn a trick, if there is one.
    Thanks!
    Jul 2005
    central Illinois
    245
    1187
    99
    Growing up in my dad's shop dismounting 10 x 20's, dad always said go buy us some Coke's, pour some on the rim /tube interface and be patient as we drank our Coke and took a break.
    I know it seems old school silly, but "seemed" to do the trick more than not. Probably a better chemical to use now a days, but I always enjoyed the Coke break with my dad.
  3. Likes M.B. Naegle, SIP6A liked this post
    Jan 2007
    Norfolk, UK
    19,918
    15354
    15636
    Old fashioned (1960's & 70's type if that helps??) brake fluid is a lovely penetrating rubber lube.
    BOTOH ANYTHING to do with tyres is an almighty PITA & hard graft.
    Mar 2010
    Davidson NC USA
    1,473
    548
    872
    Three or four young men taking turns with the tire hammer will make it easier for you.
  6. Likes dalmatiangirl61 liked this post
  7. #5
    Jun 2006
    Kansas
    1,507
    286
    565
    Yep, that can be a real problem. If the tire is junk I have got it out in the yard and using the backhoe holding the tire down with outrigger and using the bucket to pry the tire off. I have had to cut them off too. Be sure to sand and buff the rust off the wheel when going back together if not the flap will hang up and cause problems. A coat of paint or primer wouldn’t hurt either.
  8. Likes Limy Sami liked this post
  9. #6
    Aug 2011
    new plymouth id
    429
    27
    102
    I have done the outrigger trick too. and lots of straight dish soap. usually if a tire is stuck on that good its to old to use anyway, at least on public roads. im paranoid about old tires. after the ring is off, what about a nice hot camp fire at night?, toss it in then all you deal with is the wires the next morning ,lol, im joking, dont do that
  10. #7
    Mar 2005
    Kansas
    7,925
    489
    3772
    Quote Originally Posted by magneticanomaly View Post
    Those are the true "widow maker" rims that are illegal to repair. They separate by turning one half about 1/3 of a turn and then the two halves separate. The problem is the latches. They are difficult to get indexed properly when new, and with a little corrosion will blow off even when properly assembled.
  11. Likes JohnEvans, magneticanomaly liked this post
  12. #8
    May 2002
    South Central PA
    13,902
    2438
    3684
    My way is to call the road service tire guy. The hydraulic tools that they have make it look easy and the guys that do that job don't seem to mind it. I hate truck tires so it's an easy decision to spend the few $ needed.
  13. Likes Limy Sami liked this post
  14. #9
    Jul 2003
    savannah, jaw-ja
    1,809
    1422
    450
    Long ago I worked with a fellow that had a nice crescent shaped crease in his forehead. He got it working in a tire shop. Split rim got him.
  15. #10
    Feb 2020
    73
    29
    go get some murphys tube and tire compound
    soak it down good with murphys
    dreak down the ring side and get the ring off
    soak it down some more
    pull the valve core and air the tire up til the bead comes all the way off
    than let the air out
    flip upside down on a dayton wheel if you dont have the proper stand
    soak it down again and warm up the inside of the wheel with a hammer
    breakdown the far side of the tire
  16. Likes magneticanomaly liked this post
  17. #11
    Oct 2009
    Oregon
    4,903
    5311
    2521
    Fit a modern tubeless wheel to the old wheel center?
    I have a set of 5 34x7.50-17 centersplit "widowmaker" wheels with logger lug retread bias plies on them. In 20 years I have never added air to them. Had to use them in a pinch a couple times, once for a journey across several states towing a heavy trailer. I wouldn't dare take them apart, but I can't bring myself to toss them out.
  18. Likes magneticanomaly liked this post
  19. #12
    Jun 2006
    Kansas
    1,507
    286
    565
    Quote Originally Posted by Mud View Post
    Gbent is right road side or any tire shop wouldn’t consider fixing those wheels. Split rim is different than locking ring rims.
    Not having a tire cage I chain them with 3/8” chain and lay forklift tines on top to air them up.
  20. #13
    Aug 2011
    new plymouth id
    429
    27
    102
    Here is a couple of old time farmers just getting it done skip toward the end,
    https://m.youtube.com/watch?v=k8FxYcfSZlU
  21. #14
    Dec 2012
    AUSTRALIA
    2,904
    12
    947
    Be sure to get the lock rim/s and wheel that are matched ...there are many different designs and while most fit together ,they are not secure.......Possibly the safest are the kind that have a extended ledge on the ring that extends inside the adjacent bead,and cannot possibly come off.....the worst I have ever come across were WW2 Budd rims fitted to Diamond T and Mack 6x6s,with a loose collet held by two loose rivets .....this kind can blow off fully inflated on a truck.
  22. #15
    Mar 2007
    2,124
    941
    739
    Thanks for all the info, suggestions, and sympathy.
    I love Garwood's story of the immortal tires. I have had a few like that. 17.5 rims on the old centers would be nice, but good used tires are hard to find. 16's are everywhere.
    Winn's way is pretty much the best I have tried, ''though I should invest in lube, or Coke. Air blows the first bead off nicely (if the tire will hold air at all), but beating down that other side is what I hoped for a trick for.
    I liked the farmers' big yellow tire machine, too, but I ain't got one...and the good part, getting it off, he did not show us.
    I do scale 'em, wire brush 'em, Ospho 'em, and paint 'em when I have time before putting back together, and boy , it is easier the second time around.
    If I ever build the big H-frame press I want, with enough width between the columns, seems with proper "punch" and support ring (AND enough ram travel) it should be easy to just press them out. Does anyone do this?
  23. #16
    Dec 2012
    AUSTRALIA
    2,904
    12
    947
    I used to buy the tyre presses from the army sales ....not a great deal of use ,really stuck tyres turn the bead inside out and still hang onto the rim....Still ,I only paid scrap price ,and there was a lot of salvage in them...hydraulics ,heavy fabricated steel frames ,pumps ,lots of 1/2" thick adaptor plates ........still got some of them with trees growing up thru the frames.......None of the tyre shops are interested ,they just use jackhammers on rusted beads,or refuse the job......anyway ,its all tubeless now and ally wheels ,nothing else on trucks .
  24. Likes magneticanomaly liked this post
  25. #17
    Aug 2003
    port allen, louisiana usa
    1,790
    504
    422
    Quote Originally Posted by Rudd View Post
    A man was killed not far from here working on a truck tire.. Seems he did not have it in a cage or chained and the lock ring blew off and hit him in the head...At one place I worked, we would lower forklift forks on the tire and use a clip on tire chuck to inflate the tire... Never saw one come loose, but I doubt seriously that the ring would have gone far with the blades and carriage of a forklift resting on it.. NEVER trust a lock rim! Cheers; Ramsay 1
