maynah,
Right side table handwheel and the drive gear for the inner ring.
Right-side handwheel, I can sub something else so you can have an original. Same again, "balanced" lever, opposite end, if you need that as well.
Drive gear, shaft, mini-crank handle for the universal table's angle-setting I need with the rest of the whole table, both of the X-Y (plus rotation) top two-axes & mounts down thru swivel plate, "female" dovetail & gib for the axis under it.
Not overly fussed either way as to "in-out" leadscrew, nut, shaft, bearings, or handwheel.
Fair certain I'll have to got about all that in a slightly different manner than OEM in any case.
Already told Jeff I'd stand aside, anyone doing a genuine B&S restoration wants the ENTIRE table and all its bits.
Not fair to him to cherry-pick small parts, only, tear-down labour, and leave him with a coupla hundred pounds of thence un-wanted scrap iron and no significant cash.
I'm sure we can cooperate on that, win-win all around.
Elevating handwheel and the shaft. Bent on my #2 circa 1918.
John
Knee UNDER the universal "in-out" axis I don't need any of. Not even the "male" dovetail for in-out.
No collision on any parts of the elevation axis, "knee" casting, its gib, locks, screw, cranks atall.
