Please help identify Butler lathe
Results 1 to 17 of 17
    May 2020
    CANADA
    Saskatchewan
    6
    5
    Default Please help identify Butler lathe
    Hi,
    My first post here so please bear with me!
    I just picked up (not really--it's Heavy!) an old wartime (I think) Butler lathe.
    It's a gap lathe, measures about 14-34 x 6 ft bed.
    It has some interesting features including what seems to be a geared system for tapers!
    I'll post some pictures if I can figure out how!!!
    Jim
    May 2020
    CANADA
    Saskatchewan
    6
    5
    How can I add a picture?
    Dec 2012
    AUSTRALIA
    2,886
    12
    943
    More likely a relieveing system for making milling cutters.
    May 2020
    CANADA
    Saskatchewan
    6
    5
    This is as I got it
  5. Likes Peter S, Asquith liked this post
    Jan 2007
    Norfolk, UK
    19,889
    15337
    15607
    That is old old !
    Have you had a good furtle through Graces Guide ? Butler Machine Tool Co - Graces Guide
    Jul 2003
    savannah, jaw-ja
    1,809
    1421
    449
  8. Likes Peter S, Asquith, Diesel Gypsy liked this post
  9. #7
    Jul 2004
    Houston, TX USA
    30,890
    Yep, maybe the Great War - August 1914 to November 1918.
  10. #8
    May 2002
    Auckland, New Zealand
    4,536
    1981
    556
    Rudd - good find on the Butler lathe pdf!
    John - I think you are spot-on with dating, see attached portion of Butler history. It seems that after they joined the ABMTM Grouping c.1917, they dropped their full range of machine tools and concentrated on reciprocating machinery i.e. planers, shapers and slotters.
    Diesel Gypsy - it would be great to see some more photos please, larger if possible. I am guessing Tony on the lathes.co.uk website would appreciate some photos too as he doesn't have any Butler lathe listing as far as I can see. The Butler name reappeared on lathes in later years (1970's?) when they were part of B. Elliot & Co.
  11. Likes Jim Christie, Asquith, Diesel Gypsy liked this post
  12. #9
    May 2020
    CANADA
    Saskatchewan
    6
    5
    It's painted army green beneath all the grime. I suspected it was a wartime unit but which war? I'm thinking John is right - WW1
    Every moves and slides... slow and stiff!
    The drive motor is woefully inadequate, only 1.5hp and set up the way it is only turns about 60 rpm in high gear. ��
    But not much wear so hopefully I can get some use from it.
    Just got it slid into my shop today. I figure it likely weights at least 4000 lbs.
    Thanks for the helping identify it. I'll look up those links right away.
    Peter, I will post some more pictures tomorrow.
  13. #10
    May 2020
    CANADA
    Saskatchewan
    6
    5
    Rudd, you are right, page 6 of the PDF appears to be the same machine. On page 7 the listing for 8" unit looks about right. Even the weight is exactly what I thought, slightly over 4000 lbs. Thanks!
    I still don't know why they would make the saddle (carriage) power drive run together with the powered cross slide? It engages with one of the turn knobs on the side of the carriage.
  14. #11
    Apr 2006
    Manchester, England
    8,759
    1382
    5704
    Quote Originally Posted by Diesel Gypsy View Post
    Some " Craven " lathes had a similar feature, they called it " coning ".
    " Butler " started making lathes again when they became part of the BEC Elliot group and demand for planers fell off in the 1960's. The lathe was known as the " Concord ", some liked them, some didn't. I wasn't a fan. The headstock design was ok apart from the " Matrix " clutches being a size too small and therefore requiring a lot of adjustment. The apron design was flimsy and ill thought out being more prone to coolant rot than normal.
    Regards Tyrone.
  15. Likes Asquith, Diesel Gypsy, Peter S liked this post
  16. #12
    Oct 2006
    Norfolk, UK
    884
    878
    358
    As Peter said,Butler specialised many years ago and then they did what they did really well. Many years ago I saw a gear head Butler lathe,and thought it was pretty average.
  17. #13
    Oct 2006
    Norfolk, UK
    884
    878
    358
    Tyrone-re apron rot,I think the chosen coolant is the determinant. Where I worked,we had a row of smart DSGs which suffered badly with this lurgy. The coolant was Cimcool.
  18. #14
    Apr 2006
    Manchester, England
    8,759
    1382
    5704
    Quote Originally Posted by TedinNorfolk View Post
    We got a " coolant expert " in once Ted. He recommended a French brand, we tried it and it was OK rot wise and it smelt really nice but when it dried up it turned into a glue. After about 3 months all the operators were complaining about the slideways being really hard to move. It was great for me because I got about 6 months work out of it taking all the machines apart to remove the glue.
    Regards Tyrone.
  19. Likes Paolo_MD, 3512B, TedinNorfolk liked this post
  20. #15
    May 2020
    CANADA
    Saskatchewan
    6
    5
    As promised here are some more pictures
  21. Likes Paolo_MD, Peter S, TedinNorfolk liked this post
  22. #16
    Oct 2006
    Norfolk, UK
    884
    878
    358
    ....and history repeated itself where I worked in Lynn,only this time it was a row of Clchesters and the coolant was a pale green whereas the Cimcool was pink. And it was me they got to deal with them,whereas at Cambridge it was old Willy.
  23. #17
    Apr 2006
    Manchester, England
    8,759
    1382
    5704
    This stuff wwas pale green also.
    Regards Tyrone.
  24. Likes TedinNorfolk liked this post
