Powermatic 1500 Drill Press with rust - worth refurbishing?
Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    Jan 2017
    Georgia
    8
    22
    Default Powermatic 1500 Drill Press with rust - worth refurbishing?
    Is it feasible to refurbish a rusting Powermatic 1500 bench drill press (see image)?
    If so, how best to proceed? Disassemble as much as possible and wire brush?
    My goal is to make it a working machine for home shop use, and I'd be happy to preserve a vintage classic - but not if it takes weeks of effort.
    Suggestions?
    MODEL NUMBER is actually 1150.
    Jan 2012
    Midland, Texas
    1,469
    462
    739
    If this is a family heirloom, it might be worth it. If you picked it up at a garage sale, probably not. If you want to use it, I'd recommend spraying it down with Fluid Film or similar product and go over it with a ScotchBrite pad. I probably wouldn't spend more than an hour on it myself.
  3. Likes jbbenni liked this post
    Oct 2012
    Virginia
    10,268
    5843
    4622
    Quote Originally Posted by jbbenni View Post
    Suggestions?
    Twice lived with the noisy, ugly, "racing stripe" painted buggers - one BRAND NEW, the other nearly so - on Day Jobs.
    Noisy, ugly, cheap-jack all over, about as "classic" as an ignorant cement block.
    They did, however, make decent enough holes, and all-shift, all-week, all-year long. On its worst days, it should make light lunch of Harbour Freight wannabees.
    Even so, Hong Kong Harbour will freeze full-depth before I'd bother to haul one home.
    My advice is a basic wash & brush-up, disassembly not-so-much, use it as-had until it breaks something expensive, at which point - and that could be many years out - I'd scrap it.
    Think of it as a Ford pickup built in a time when Ford had no money for niceties - just the basics of frame, cab, bed, and make-it-go-down-the-road parts.
  5. Likes jbbenni liked this post
  6. #4
    Mar 2006
    Wisconsin
    1,041
    14
    349
    If rust is your only problem you should be able to bring the machine back to life in a few days. I would disassemble it and use Scotchbrite pads on the column. If there are more problems like bad bearings, bad taper for mounting the chuck, or a scored spindle, I would get some prices on parts. If the prices get in the neighborhood of 50% of a similar size replacement I would just buy a replacement machine.
  7. Likes jbbenni liked this post
  8. #5
    Apr 2017
    FINLAND
    199
    36
    52
    Looking at the picture, wipe it with solvent rag and run it like you stole it.
    Machines are ment to be used not to be pretty. Clean yes but that's it.
    Marko
  9. Likes jbbenni, JohnEvans, Salem Straub liked this post
  10. #6
    Apr 2007
    West Virginia
    990
    469
    390
    I am not familiar with the 1500 and a google search did not produce anything. Looks like an 1150 to me. I am familiar with the 1150 (have one) and the 1200. Both are better than 95% of the drill presses that you will find around in my opinion and about the best you will find in the price range that I see them in ($500+/-). As far as the rust it does not look bad to me. I suspect it will clean up fine it's just a matter of how much time you have and how much they want.
  11. Likes jbbenni liked this post
  12. #7
    Jan 2017
    Oregon
    2,247
    407
    1633
    Suggestions?
    It's this drill press?
    PowerMatic Drill Press Model 15 44 Volts 3 Phase | eBay
    You have 440 3 phase in your home shop?
  13. Likes projectnut, jbbenni liked this post
  14. #8
    Jan 2017
    Georgia
    8
    22
    Yup - my bad. It IS an 1150.
  15. #9
    Mar 2006
    Wisconsin
    1,041
    14
    349
    440 3 phase isn't necessary. Almost any motor of that size is dual voltage 220/440. It can be run off a 20 amp 220 single phase outlet with a static phase converter. American Rotary Phase Converter makes a 1/2 - 3 hp static converter that sells for $65.00 with free shipping from their eBay store. I have 2 machines running from their static converters, a 2 hp Sheldon lathe and a 1 hp Racine power hacksaw.
    There should be a wiring diagram either on the side of the motor or inside the wiring box that gives the proper connections for either 440 or 220.
  16. Likes jbbenni liked this post
  17. #10
    Jan 2017
    Georgia
    8
    22
    Yes - thanks ProjectNut. That's my plan. This motor, like many others, is dual voltage so can be reconfigured to run as 240VAC 3ph.
    And then I'm looking at using a KB27D VFD which would provide the phase conversion and also extend the speed range. (Offer even lower speeds at constant torque but reduced power). The KB27D is useful for other devices, but if I decide to dedicate a power feed I appreciate the tip on the Rotary Phase Converter. Thank you!
  18. #11
    Jul 2004
    N. GA- 33.992N , -83.72W usa
    3,758
    62
    864
    unless it has been abused, i'd bet it works just fine. hose it down with liquid wrench or wd40 and use a wire wheel or
    scotchbrite on the rusty bits . clean and oil the chuck.
    also it's a DRILL PRESS! it doesn't have to be perfect . it should be ugly.
    i use a cheap drill press for quick and
    dirty stuff, stuff that doesn't need to be perfect, wood drilling , second ops, stuff i don't want near a milling table
    or don't want to break down a setup on another machine.. non-drilling ops like small wire wheels or sanding drums .
    it doesn't have to be an Edlund or Fosdick to be useful.
  19. Likes jbbenni liked this post
  20. #12
    Oct 2012
    Virginia
    10,268
    5843
    4622
    Quote Originally Posted by tnmgcarbide View Post
    Too easily pleased you are. "Medium eggplant" grade, as serious DP's go, the both of those.
  21. Likes tnmgcarbide liked this post
  22. #13
    Apr 2007
    West Virginia
    990
    469
    390
    Quote Originally Posted by jancollc View Post
    As projectnut said it can be run on 240v. I installed a vfd on mine and run it off 1ph. Nice value added feature since I can really slow it down for countersinking and tapping. Or for about the same money you can put a 1ph motor on it. Only 3/4hp as I recall.
  23. Likes jbbenni liked this post
  24. #14
    Aug 2017
    75
    9
    16
    Quote Originally Posted by Monarchist View Post
    What do you dislike about them? What drill press would you recommend instead?
    I am just curious because I have thought about buying one to replace my junky Chinese drill. I would prefer a 20" model but I wouldn't hesitate on an 1150 for the right price.
  25. #15
    Oct 2005
    14,074
    The OP is a self declared "harry Homeshop" and should really go to
    the Homeshop fourm pages for this query.
  26. #16
    Apr 2004
    Shandaken, NY, USA
    4,220
    1097
    6621
    I bought a used Powermatic 15" floor model drill about 32 years ago. It is a 1965 machine, so has a rounded belt guard rather than the "styled" squared-off belt guard with the racing stripe. It is a great drill press. I use it for all kinds of drilling up to about 5/8" in steel. I have no complaints about the Powermatic drill. It is a round-column drill with vee belt drive. If that's all a person expects it to be, then it is fine.
    I paid 200 bucks for my Powermatic drill. The seller- one of the old Centre Street used machinery dealers in NYC- had wanted $300. We plugged it in and I ran it on the highest spindle speeds. Spindle bearings had a squeal in them. The dealer knocked off 100 bucks. Bearings, at the time, stood me all of 27 bucks from Kaman. I've been using that Powermatic drill ever since. It is a handy machine, and being a floor model, the extra height capacity is a very handy feature.
    At the powerplant, we had a Powermatic 15" drill of the same model as mine. It was beat on, abused, and often-times people were running huge turned shank drills in it, pushing thru steel. It stood up to that treatment. When we re-tooled the machine shop in the powerplant, I replaced it with a variable speed Clausing drill with number 3 MT shank- hoping to break people of the habit of using those turned-shank drills in a light duty machine. We also replaced a Johannson radial drill ( a ridiculously liught machine with a number 5 MT spindle) with a REAL radial drill- a Carlton.
    I did buy 3 new Powermatic variable speed drills for use in the fleet garage and at two remote hydroelectric plants when I was employed by the NY Power Authority. No one had any complaints about the Powermatic drills. By the time I purchased the 3 variable speed Powermatic drills, they were still made in USA, but painted gold.
    They stood the gaff of being used, abused, and hardly maintained. People would need to make a large opening in an electrical box, so would think nothing of running hole saws in the Powermatic drills. I used to wince and grit my teeth when I'd see that happening.
    The Powermatic drill in this thread does not look bad. Light rust on the column which should clean up with some "Scotchbrite" pads and penetrating oil or diesel fuel.
    The costliest bearings on these Powermatic drills are the bearings in the cone pulley. These bearings take the side-load from the belt and transfer it from the pulley to the head of the drill press. As far as I know, my drill has the original bearings in the cone pulley, now over 50 years old.
    Powermatic put a bit more iron into their drill presses than Delta or Rockwell. Having familiarity with most of the light drill presses, I can say that the head casting is a bit beefier than similarly sized drills made by the popular old US manufacturers. It is more than an adequate machine for home shops and for light machine shop work. Having seen the sorry excuses for drill presses coming out of Asia, that Powermatic will eat any of them for a snack.
  27. Likes Monarchist, Pete Deal, jbbenni liked this post
  28. #17
    Oct 2012
    Virginia
    10,268
    5843
    4622
    Quote Originally Posted by jwearing View Post
    I WANTED an Alzmetall AB3 or AB4. Blame Milacron for infecting me with that virus.
    A PM member near Louisville, KY turned up with the heavier (about 4,400 lbs) 7.5 HP Alzmetall AB5/S for sale, so I hauled it back to Sterling/Dulles, Virginia.
    Alzmetall AB5
    It clears my low (eight foot) ceiling with the top oiler removed and adapted to a side-feed, so I have that instead of the small radial I had been wishing I had space for.
    My go-to for forty years was - and still IS for light work - a pre-Kearny & Trecker take-over 1940's vintage Walker-Turner 15" bench model. Walker-Turner's have no "right" to be as good as drillpressen as they have proven to be, but there you have it. Like Old Fords and a natural stone, they seem to last forever.
    Powermatic's with the Reeves (type) Vari-drive, and very similar Clausings, are actually seriously useful medium-duty column DP's. Also noisy. The Clausing's were a bit nicer finished and smoother, the Powermatics crude, rude and prone to shout "cheapskate!", but time proved them rugged enough for their price.
    "Day Job", I've spent the most time on Hamilton sensitives, ATW 5 and 8 foot radials, and a 3-foot Cincinnati-Bickford radial. I LOVE radials for their positioning flexibility, but home-shop compact they are not. The AB5/S is actually more powerful than many radials as much as ten thousand lbs, Avoir, heavier and needing four times the floorspace.
    Your "bench" model Powermatic, or my W-T have an edge over full-column types. The column does not extend below the support, but CAN be extended ABOVE it. W-T made "beam clamps" to hang the DP from overhead. Not hard to DIY fab.
    Using that sort of mount with a WF I-beam that spans my garage/shop, I can put an inch-plus Silver & Deming, or a six-inch hole saw at the middle of about a 15 FOOT circle, not just a 15 INCH one.
  29. #18
    Oct 2012
    Virginia
    10,268
    5843
    4622
    Noooo he should not!
    Some of those fools will be "rebuilding" twelve-ounce Chicom white metal castings with Delrin plastic sleeves and thinking that makes a POS into an actual DP. With Ewe's Tubes videos, yet!
    Powermatics are crude buggers, but they are "crude" like old Caterpiggle bulldozers. Nothing wimpy about them that would gain from plastic bushings. They just get the job DONE.
  30. #19
    Mar 2009
    4,827
    89
    892
    Is it feasible to refurbish a rusting Powermatic 1500 bench drill press?
    You do not state how many hours a day you have to work on it. If it is just rust removal then you may encounter seized parts and other surprises. Your level of acceptance is going to determine how long it takes. For a professional job you can count on many hours.
  31. #20
    Jul 2011
    PA, USA
    340
    6
    189
    Yes, ... perspectives DO vary.
    With the demise of manufacturing in the US, there are fewer folks who have hands-on experience with REAL tools.
