Warning: I'm long winded.
Hi everyone,
I have a fairly early Hendey 14x6 conehead lathe. If it makes any difference, the serial number is 5180. It's an earlier model than the tie bar model.
I haven't had good experiences taking work out of the chuck and putting it back in and getting any consistency. I should mention that I am really new to machining, and this probably does not help me at all.
When I bought the lathe, the gentleman who owned it told me that I really should replace the chuck, but he didn't go into any detail with me about why (and I didn't know enough to ask). Now that I am actually trying to make parts with the lathe, I see the current chuck as a liability when trying to make parts that require chuck removal and reinsertion. I have tried turing between centers, but I usually end up with chatter during the cut; I do not have a follow rest for the lathe yet perhaps that could help.
I purchased a Pratt Burnerd 8 inch 3 jaw chuck without any adapters, and I plan to make the adapter. This is really what I am worried about. No matter how accurate the chuck is, if I don't do a good job on the adapter, the new chuck will be $1200 bucks worth of paper weight.
I know that the spindle threads are 8tpi, but I am pretty naive about threading in general and I am a bit confused by all of the posts I read about threads. I know there is a lot of engineering behind how the different types of threads work, and I really don't know how to figure out what type of threads the Hendey spindle has. I can do trial and error, that's proabably about the only thing I have going for me, but that's not cheap considering the cost of the stock I'm going to need in order to make the adapter. I'm a bit ashamed to admit that right now it's not uncommon for me to make a part 3 times before I get it right, and that's with pretty simple stuff.
Is there any advice anyone can give me about cutting these threads? Is it important that the adapter always go onto the threads the exact same distance everytime I take the chuck off and put it back on the lathe spindle? Does the adapter need to stop precisely at the same spot in relation to the spindle threads? I planned to create the threads, spin the adapter onto the spindle, and then machine the face for the chuck.
Are there any tricks that can help me so that removing and reinstalling the chuck will allow it to run very close to true every time?
Thank you for your help,
Dan
Hi everyone,
Dan
