twalsh341
- Nov 12, 2008
- Philadelphia, PA
I just bought a 5C version with plain spindle journals, and a bunch of goodies. As expected the frosting is untouched under the headstock but worn elsewhere along the bed. I've got quotes out to some local way grinding companies, a copy of Machine Tool Reconditioning which is dense but fun reading.
My plan is to get the lathe working mechanically, redoing the worn out felts and cleaning out the oil system adjusting the gibs on the compound etc. while I learn scraping and make gauges for testing the angle of the side ways.
As far as the rebuild goes, would this be a good procedure to follow, Bed ways are ground flat using the back t slot for parallel reference, from this scrape the angled sides of the headstock to fit the bed (the frosted flat surface will level the headstock axis in the horizontal plane to the bed), the angled surfaces will be scraped to allow the flat to seat fully and to align the headstock parallel to the t slot in back, finally moglice the tailstock on jigs to alight the quill.
In particular I'm looking for feedback from Forrest on this, but does this seem like a reasoned approach? Is there anything I'm missing, recommendations or suggestions?
Trevor Walsh
Trevor Walsh
