Last night started working on RP Apron.
Can someone tell me if the right clutch dog (which seems to be missing in left photo) to reverse the feed is missing on this Reed Prentice apron? or do you simply use the reverse lever on the apron that works a reverse mechanism in front of the line shaft pulley.
The lathe was unloaded in my barn, disassembled, cleaned and moved to my basement. That was 3 months ago and I vaguely remember something hitting the dirt floor when I pulled the feed rod out.
Also how much backlash where feed rod engages the bevel gear is too much, seems very loose to me?
Please forgive my ignorance, very new at this.
