awander
Stainless
- Jun 11, 2012
- Eastern PA
I've had this old Reid surface grinder for 3 or 4 years, and I've never used it-it has been waiting for me to devise a method to get it from the garage to the shop, over some uneven ground.
Well, I finally got it moved, and in doing so, I broke one end off the cable that drives the tables "side-to--side".
Near as I can tell, it is a Reid Model 2 (no "a" or "-1" or anything else). All of the mechanism for auto feed and movement has been stripped by some previous owner, it simply has 3 handwheels, one for each axis.
I need to replace the motor, but in the meantime, I am trying to repair the transverse feed. It seems as if this is simply a cable that wraps once around a small drum that is geared to the handwheel. The cable attaches to each end of the table, and turning the drum moves the cable, moving the table.
I made up a new cable with threaded adjusters on both ends, and when I snug it up, I do get the proper motion of the table when turning the handwheel-but starting at about 6 inches from center of travel, in both directions, it makes a loud "creaking" noise that sounds like the cable is rubbing the machine bed, or against itself. I've tried using the original cable, and a couple of slightly different-diameter cables, with either a simple single wrap around the pulley, or 2 wraps around, and always get the same results-it works, but it makes that noise.
This pulley/drum is simply a gear with a square slot in it, about 1/4" or 3/8" wide. i have seen some info in other threads about cable-drive surface grinders that used a grooved or "threaded" drum for the cable, but this grinder just has the simple single groove.
I've searched for a manual or a parts diagram for this machine with no luck. There is a brochure on the No 2 on Vintagemachinery,org, but no manuals of any kind, and I haven't been able to find much info.
There is no model marked on the grinder; I identified it using the brochure at vintagemachinery,org.
Is there anyone reading this who has knowledge of how this thing is supposed to work?
Is it normal for the cable drives to make noise? I can't believe that would lead to a good ground finish.
Should I try a plastic-coated cable?
Any insight would be greatly appreciated.
Andy
Andy
