wheels17
Stainless
- May 10, 2012
- Pittsford, NY
I've previously posted some of the things that we've seen at the Tool Thrift Shop where I volunteer. We have a couple of things that were donated that I need help with.
The first are these small collets. We have most of a quart jar of them. I apologize for the poor quality of the cellphone picture in advance.
The overall length is about 1 1/4" and they have "DALE" stamped on them. The thread major diameter measures .2575" (6.5mm?) and is 40 TPI. The bore is .196", and the key slot is .0675" wide. The diameter of the collett at the key slot is .2998".
Looking for help in identifying these colletts.
We also received a lot of parts that seem to fit a 1 1/4-10 threaded spindle (3-jaw chucks, drill chucks, internal expanding arbors, and other odd things).
There are several sets of these parts:
The od of the parts is about 1.75, and BOTH are threaded 1 1/4-10 on the interior. Something thin could be secured between them and reversed on the spindle if desired. The thread on the joining screw is quite fine, but I did not measure it. Guessing near 40tpi.
Does anyone have any idea for their use, or the lathe that might use that spindle thread?
