Removing Drive Gear On Keller 3C Power Hacksaw
Likes Likes:  0
Results 1 to 3 of 3
    May 2008
    Canada
    95
    Default Removing Drive Gear On Keller 3C Power Hacksaw
    I'm removing the drive gear on a Keller 3c power hacksaw and am wondering if there is any reason I cannot hammer on the shaft end pushing the shaft and crank shaft disc out the other side. I don't really want to use a gear puller as I can only get a hold of the gear on the edge. I've taken out the set screw for the gear and loaded it up with Kroil but it seems to be well stuck on the shaft.
    Thanks for any help people can provide !
    Lewis
    Jul 2020
    488
    176
    93
    Quote Originally Posted by LewisCobb View Post
    Lewis
    picture is worth a 1000 words, may help
    May 2008
    Canada
    95
    I'll post up a few pics when I am back at the house later but I may have discovered something that might be fetching the gear up. Looks like a ding on the end of the shaft has created a bit of a burr that is preventing the gear from slipping off. I almost didn't see it as it's under a mess of paint. I tried filing it down but it's so close to the gear surface I'd never truly get rid of it - just reduce it to a small fillet. I'm now thinking about removing the key somehow, then rotating the gear so that the key notch lines up with the burr on the shaft. It will slip off then or being able to get a file at it in that position would remove it quickly.
