Removing Monarch 16CY main drive pully/clutch
Likes Likes:  0
Results 1 to 2 of 2
    Dec 2016
    New York
    452
    6
    175
    Default Removing Monarch 16CY main drive pully/clutch
    I'm deep in the seemingly endless clean-up and de-greasing of this new to me machine. It would make cleaning a bit easier if i were to remove the cast guard over the drive pulleys but it looks like i need to remove the pulley/clutch assembly. It looks like one nut on the pulley shaft and the whole thing will come out. Can it really be that simple? Am i missing something? I see how the clutch is adjusted and i can easily maintain that adjustment. If'm im going to create a problem for myself i'll just leave well enough alone and clean it as it is.
    Mark
    Jul 2004
    Houston, TX USA
    29,665
    Probably similar to this CM drawing - big bearings inside pulley
