Repair crack in Shape-rite crank link (was Opinions on how to repair)
Page 1 of 2 12 LastLast
Results 1 to 20 of 35
    Mar 2019
    Virginia
    21
    15
    Default Repair crack in Shape-rite crank link (was Opinions on how to repair)
    I have been reviewing my options to repair this piece. It is part of a cast iron rocker arm to a Shape-rite shaper. I have never welded and dont have a welder so that is out. Other options include jb weld, brazing and pinning such as with the lock-n-stitch products. Anything I am missing? how would you guys go about this?
    May 2017
    Massachusetts
    270
    253
    131
    Grind back a vee groove on either side of the crack and fill that vee groove with braze.
    Or remanufacture the piece out of steel.
    Jan 2011
    BFE Nevada/San Marcos Tx
    1,043
    915
    542
    Take it to someone that can weld/braze cast iron, or make another. Without knowing how that is used, would it be possible to replace that piece with a large link of drive chain?
    Oct 2004
    Elyria Ohio
    1,785
    3358
    728
    I second the grinding a vee and brazing approach - probably last you the rest of your life.
  5. Likes M.B. Naegle liked this post
    Dec 2016
    Wisconsin
    89
    16
    TIG with pure nickle. Keep it cold as possible and bury it in welding blankets for the night to cool
  7. Likes M.B. Naegle liked this post
  8. #6
    Feb 2008
    105
    17
    I'd also vee it and braze it. If you have a lathe turn a carbon plug for the hole before you braze it. The plug will keep the braze from getting into the bore and it will not stick to the carbon.
  9. Likes Adam Selene liked this post
  10. #7
    Mar 2019
    Virginia
    21
    15
    Quote Originally Posted by kubiack View Post
    As in carbon welding plate? where would I get carbon?
    Looks like brazing method is most popular. I have considered just making one from steel and it may come to that if i botch this up (i will take dimensions before I attempt anything). Everything I have read implies that cast iron is sensitive to heating and sudden cooling. Thinking through how I would do this, I would have to braze one side, flip it and braze the other side as the crack runs on both sides of the set screw. That reheating wouldn't be a concern would it?
    That set screw is not critical. I can move it even to the other ear that is not cracked. Is there nothing that could be used in the bore to keep the halves together?
    Thanks for the thoughts on this.
  11. #8
    Feb 2008
    105
    17
    My local welding shop keeps Arcair carbon rods in stock in various sizes.
    Arcair Carbon Rods
  12. #9
    Mar 2019
    Virginia
    21
    15
    Arcair Carbon Rods
    Ah guess i would have known that if I had ever welded. Thanks.
  13. #10
    Feb 2011
    2,046
    1387
    877
    In regards to heat: I've had decent luck brazing cast iron with a decent sized rose-bud rather than a small tip. If the material can take the heat, don't be afraid to heat up a large portion of the part rather than just a little bitty spot. From my experience, that's where cracking really becomes an issue, not so much with how much heat is there but with how evenly it is dispersed and how quickly it dissipates. The heat will help clean the break and let the filler rod really soak into it rather than just adding a ball on the surface. However at this point the other risk is actually melting the iron but as long as you only get it hot enough for the filler to soak in then move on, you should be safe. The complexity of the part will also play into how stable it cools, but that part looks simple enough to just leave it out in the open to cool.
    We have a box of Lye in the welding area just for cooling welded parts. If it's something we're concerned about cracking, we'll pack it in there and it will still be too hot to touch 12 hours later.
  14. Likes Rudd, TDegenhart, Joe Miranda, Adam Selene liked this post
  15. #11
    Jan 2011
    1,043
    915
    542
    Quote Originally Posted by M.B. Naegle View Post
    Lye or Lime?
  16. #12
    Aug 2015
    Illinois
    1,348
    971
    576
    I would make a new link from steel.
  17. #13
    Feb 2005
    1,173
    905
    1016
    You can safely braze the crack. It is an unconstrained crack and it will not crack again.
  18. Likes Adam Selene liked this post
  19. #14
    Jan 2007
    Norfolk, UK
    18,598
    14138
    14105
    Quote Originally Posted by Dumpster_diving View Post
    + another on that - if the weld doesn't work you have another bite at the cherry.
  20. #15
    Mar 2013
    Surbiton, surrey, UK
    1,537
    1848
    952
    I had a problem getting the braze to wet out on CI repair, I found going over it with a needle gun after veeing out made the difference between success and utter failure, sposed to break up the graphite, or something like that.
    Cheers
    D
  21. Likes mllud22, Adam Selene liked this post
  22. #16
    Jul 2007
    Stratham, Cow Hampshire
    4,155
    389
    1500
    Quote Originally Posted by Demon73 View Post
    Cheers
    D
    Interesting thought that one. I have done a lot of cast iron brazing. I can see how your remedy would work and why. The graphite in cast iron "smears" as it is ground away. You're establishing "bare iron" by doing the needling.
    Joe in NH
  23. Likes partsproduction liked this post
  24. #17
    Feb 2018
    74
    McMaster-Carr
    McMaster stocks carbon rods.
    I would grind and braze or use a nickel electrode and weld.
  25. #18
    Oct 2013
    Texas Panhandle
    15
    Adam,
    Quite a while back I purchased a Shape-Rite from another PM member who happened to be local (I live in a machinery desert). Mine appears to have been used in production, was crashed sometime in its life, and has a brazed tool head slide repair that seems quite strong.
    Parts for these are pure unobtainum, BUT, at the moment eBay seller "kwktools" (no affiliation with me) has several Shape-Rite parts listed (door, ram clamp handle, saddle). I purchased a ram stroke pointer from him (mine had the tip broken off) and the transaction went smooth, meaning reasonable price, shipping was fast and the item was as described.
    This particular part isn't listed, but I think it would be worth your time to contact him through eBay and ask if he has the rocker arm. From what I can tell, he is parting out a Model B.
    Here's a link to his currently listed items:
    https://www.ebay.com/sch/kwktools/m....p2047675.l2562
    By the way, do you have the later "Model B", or, like mine, the earlier "HY DUTY". Both are 8" stroke.
    Good Luck,
    Tenaya
  26. Likes dalmatiangirl61, Adam Selene liked this post
  27. #19
    Mar 2013
    1,537
    1848
    952
    Quote Originally Posted by Joe in NH View Post
    Joe in NH
    Thought I was going mad at one point, was sent some info that suggested shot blasting, I figured the needle gun wasnt a mile away from that so gave it a go, thankfully it worked.
    Heres the trip.
  28. #20
    Feb 2011
    2,046
    1387
    877
    Quote Originally Posted by dalmatiangirl61 View Post
    Lye or Lime?
    Lime, sorry
  29. Likes dalmatiangirl61 liked this post
