Rhodes 7" lineshaft shaper - FS
Results 1 to 6 of 6
    May 2001
    Caldwell, NJ
    31
    5
    Default Rhodes 7" lineshaft shaper - FS
    I have listed my Rhodes 7" lineshaft shaper for sale - FYI
    Rhodes 7" Metal Shaper - antique - tools - by owner - sale
    Hope this is the right location to post this.
    Feb 2013
    Virginia
    698
    165
    64
    I would buy this if it were closer.
  3. Likes M.B. Naegle, Matt_Maguire liked this post
    Feb 2011
    2,203
    1613
    935
    Looks like he did a decent job making a make-shift wood cone pulley for the jack-shaft. I've got a couple old machines I'll need to do that on.
    Sep 2014
    Georgia
    424
    608
    216
    Quote Originally Posted by Dean View Post
    Fantastic looking machine!!
    Jul 2006
    Cumberland, Maine
    451
    44
    94
    Very interesting!
    I too have an old Rhodes. Have never been able to find a serial number, but I have always thought it was late 1920ish. It is a Hartford-made machine - prior to their move to Waltham, MA. Like the one posted, it has three T slots in the table. There is a lip at the bottom of the main casting, but it extends only 1/2 inch or so from the vertical way face. The one Dean posted has a much longer lip, which makes little sense to me as it seems to serve no real purpose. The lip on mine ends with the cast base. The long lip on the shaper in the post extends well over the base casting, and is supported only by the chip tray. Or maybe that’s not a separate chip tray, but instead is part of the base casting. Mine does not have a chip tray - either separate or integral with the base or the main casting.
    Looking at the pics on Tony’s lathes.co.uk site, I see that the vertical ways (later machines) extend right to the base. Mine stop well above the lip, as with Dean’s pics.
    Both Dean’s and mine were made strictly as lineshaft machines. The later Waltham-made machines apparently had fixings for an electric motor cast onto the base.
    The motor on mine is ancient - looks older than Dean’s, but who knows when they were converted from lineshaft drive. Everything - motor, two V belt jackshafts with user-made babbitt pillow blocks, final three-step cast iron pulley for flat belt to machine - is mounted on a heavy pivoting angle iron framework.
    As I said, no serial numbers that I can find. But I do remember seeing 66 (or maybe 99?) stamped into some of the parts, which I have assumed was to identify parts for re-assembly after painting.
    Lots of history here to decipher.
    John
  7. Likes alum100k liked this post
  8. #6
    Jan 2019
    Virginia
    165
    96
    33
    Rhodes are very cool. Glad you have one.
