Rivett 608 tailstock taper - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    Virginia
    27,334
    7561
    8523
    Quote Originally Posted by JST View Post
    I've no idea what the list is of acceptable formats in Windoze........ I know jpg are obviously OK, IIRC gif and tiff it takes, also.
    Thanks, but no need to go to any great effort, after all I have the prototype here, and can take a cast from it, plus the Reed dimensions seem to be different from all the other info so far.
    Maybe if F E Reed made an 8" machine, they might have used a center as small as 2" long. The smallest Reed in any list so far was a 10", using a taper 3"+ long.
    Listed in the source I have for 12" lathes, but probably the same one you refer to:
    9/16" at small end, 3 5/8" long, rate of taper as per JARNO.
    Bill
  2. #22
    Jun 2001
    St Louis
    17,936
    1847
    3011
    The total length of the Rivett taper is 2", which lets out the smallest Reed taper I have seen....
    Since it is essentially same as jarno, it is makeable.....
    Just funny that you cannot now make a true, perfect Rivett taper from the the *actual* drawing stamped by the Rivett engineering dept........
  3. #23
    Feb 2003
    Southeastern Connecticut
    746
    19
    Pretty sure that right above where it says "To gage" the drawing shows the included angle of the taper as 2 degress and 55 minutes. Messing around with some on line trig calculators shows the approximate dimensions given for the taper as coming pretty close to that angle.
  4. Likes Giglio_A liked this post
