Results 1 to 4 of 4
Thread: Rivett chuck spanner wrench
11-10-2019, 09:14 PM #1
What size is needed to install the chucks on these?
Or is it a special size?
Anybody got a pic on one?
11-10-2019, 09:22 PM #2
Here is the tabulated drawing on the draw back nuts. See what your diameter is and check what size you need
Example - 7 1/2" OD = L1
Member Walter A sells the hook spanners
11-10-2019, 10:46 PM #3
The 1020 and 1030 have standard L0 spindles with rectangular slots in the nut for the hook spanner.
But the 918 has a special small L000 spindle, not listed in the long nose specs. So you would have to measure the ring diameter. And Tony's pictures seem to indicate you need a pin-type hook spanner because the ring has drilled holes.
LarryLast edited by L Vanice; 11-11-2019 at 10:46 AM.
11-11-2019, 01:17 AM #4
Thanks for the info. Looks like mine is about 5 3/8 at the front side but I don`t have holes just slots for the spanner.
I`ve sent a pm to Walter.Last edited by jabberwoki; 11-11-2019 at 01:24 AM. Reason: PM`D
