Dennis,
Ok here are the handwheel dimensions.
O.D. 5"
Hub O.D. 1.573"
Hub thickness 1.031"
Hub bore 0.500"
Set Screw 5/16-18
3 spoke offset hub. The inside face of the hub has a 45° chamfer on it about 0.2" wide.
The Y-axis leadscrew jam nut thread is 1/2-20
I used a citrus based paint stripper to remove old paint. A mixture of TSP in water to clean off the hard oil, grease and chip mass along with hand wire brushes and lots of elbow grease.
Yes, it's amazing how much swarf can collect inside the knee. How that stuff
gets in there I'll never know. When I unbolted the column from the base I found chips *inside* the column. There aren't any openings into the column except the bottom which is bolted to the base. How do chips get in there
Yours looks much like mine did when I got it. It had sat for a few years. Is that the original Rotex base? Mine came on an open stand someone had welded up from channel. He did a nice job getting it square and even put adjustable feet on it for leveling. I added a couple shelves to hold the tooling. I replaced the plywood base with a top of two by material and covered that with some formica I had left over from an old work bench project. Easy to wipe clean. Once it's all apart the individual pieces are light enough for one man to handle. the column of course is the heaviest piece.
By the way, I had the devils own time getting the miter gear off the knee screw. Someone had spun it and the resulting burr had locked it on tight. It took many applications of Kroil, persuading with a pickle fork and finally heat from a propane torch to loosen it up and work it off.
Bill
